Results 1 to 5 of 5
Thread: Drivers side Rear door wiring loom
    VT Berlina wagon 5.0 litre
    Jan 2006
    Default Drivers side Rear door wiring loom
    hey guys,
    ive got a VT wagon and my rear D/S door speaker and electric window has stopped working,
    i was told at Peter page holden that i need to replace the wiring loom in the door.
    Has anyone else had to do this? was it an easy job? or should i get someone to do it properly?
    any hints will be appreciated.
    VYII SS UTE
    Feb 2006
    make sure all the plugs are tight, yes could have broken wires in the rubber boot, unusual you would have 2 circuits go at the same time or were they at different times.
    do you work for air international as in the A/C suppliers?
    Jan 2006
    yeah i work at air international.
    i work in the seating section but have also worked in the Air con section aswell.
    the speakers went first the the electric windows about 1 month later.
    VYII SS UTE
    Feb 2006
    ok, was just wondering about air int
    if you can pull the rubber boot down tug an the wires individualy , if they are broken they probably will be around the middle, if it stetches at any point that is where the brake is, if you have a multi meter you can check the continuaty between the plug behind paneling and in the door., speaker may be open cicuit and not working
    Have you checked the switches, p/window motor etc. if you have a mate with the same car, see if you can borrow switches to test on your car.
    Jan 2006
    yeah i have checked all the switches abd are all in working order.
    have had a look and one of the wires have come off of the white plug near the body of the car.
    i pushed the wires together and the window worked but the speakers didnt.
    im going to just buy the wiring loom for the door and install it .
  1. VT drivers side door not opening
    By dbun in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-04-2006, 08:22 AM
  2. cant open any other door except for drivers side!!! (VP Berlina)
    By brey9186 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-03-2006, 06:24 PM
  3. How to remove Drivers side Door
    By BANGERS88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-12-2005, 03:22 PM
  4. Where to buy drivers side door seal?
    By tep_aus in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-12-2005, 10:52 AM
  5. VL Commodore drivers side door
    By huck0487 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 25-06-2005, 12:11 AM
