Results 1 to 13 of 13
Thread: Connecting a neon to where the interior/boot light would go?
    VS Commodore Omega
    Apr 2005
    Default Connecting a neon to where the interior/boot light would go?
    Hey guys,
    Just a pretty n00b like question (it's not for a Commodore but I figuire all cars are the same in regards to this). You know those cradle things where the interior lights go? The metal brackets where you clip the light into? Alright I've found a picture of it and attached it.
    Anyway, what I'm wondering is how they work? Is one side of this cradle thing 12v and the other side a ground, or are both sides 12v? The reason I'm asking is because in the boot of a car I want to add a neon and since this car is too annoying to pull apart to add some new cable I figuired it would be good to just replace the courtesy light, and the neon I bought has a black cable which is for earth I think and a red cable for 12v power.
    I want to remove the courtesy light and replace it (wrap & solder the cables onto the terminals), is this possible or just a stupid idea?
    All replies welcome, thanks heaps!
    azzfox's Avatar
    azzfox is offline slideways
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    one side is 12v and other side is ground. its not a stupid idea caus many people do it... even me
    My (ex)Ride
    Quote Originally Posted by ari666 View Post
    LMAO!!! bracelets!!! and neck chains?!?!? they are as gay as aids.
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Nice 4 year old thread dig dude....got a permit to mine that deep?
    maginoodle's Avatar
    maginoodle is offline Donating Member
    vy series2 ss crewman
    Apr 2006
    yeah what azzfox said. I saw somewhere that you can get neons that go in inplace of the original bulbs. Just put it in as normal and it works.
    VS Commodore Omega
    Apr 2005
    Awesome, thanks guys, you've made my day!
    Just another quick question, is there a way to tell which connector is which, or if I put the neon on the wrong way it won't break it, just won't light up?
    Cheers!
    1998 vt executive
    Feb 2006
    tasmania
    i have a blue neon in my boot to it took 5min to swap over very easy to do
    i use something which i don't know what it's called but it looks like a pen and has one wire coming off it.
    all you do is hook that onto bare metal then put the tip of the pen thing onto either side of the thing you are connecting it to and the power wire lights up the pen the earth doesn't very cool little thing i'm sure that'll make it easier for you but you have to find one first i got mine form autobarn. and also there not exspensive either
    Attached Thumbnails Attached Thumbnails Connecting a neon to where the interior/boot light would go?-100_1840.jpg
    azzfox's Avatar
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    that would be a test light. i used a multimeter but test light would be cheaper.
    My (ex)Ride
    azzfox's Avatar
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    Quote Originally Posted by maginoodle
    as you have probably seen in another thread i think you'r talking about those l.e.d festoon globes.
    My (ex)Ride
    VS Commodore Omega
    Apr 2005
    I've got a multimeter but wouldn't have a clue on how to use it, there's a red wire, a black wire and three holes they can go into, and it's got a dial with lots of options but I don't know what any of them mean, if you could tell me which one you use when you do it and which coloured wire would go where (in the multimeter and the car) it would be ever so appretiated!
    Thanks heaps!
    EDIT: it looks exactly like this:
    azzfox's Avatar
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    put the Black lead in "COM", Red lead in "V mA" and set it to 20V DC (as in pic). then hold Black lead on chassis (make sure its clean and no paint) and Red lead on one of the light terminals untill you get a reading of around 12.00V and that will be the posive terminal (make sure light is switched on first )
    My (ex)Ride
    Keesh's Avatar
    Keesh is offline WATSON HOLDEN
    VQ 5L Caprice, WH LS1 Statesman, VN 5L Calais
    Jan 2006
    one side + and ones - make sure the neon ur using has he inverter bulit in to the neon itself and not the cigarette plug, if u cut off a cigarette plug that has the inverter into it and wire the neon without the inverter u will short it out cause neons only use 4v.. if u have a neon that has an inverter in it the u just snip the wires and wire one side to + and the other to -, it will only work one way so why bother testing ur terminals if it doesnt work swap the wires simple
    Don't blame me, It's that damn percadan..
    If you ask me, that stuff rots your brain...
    And now a word from our new sponsor.. Percadan? oh crap!
    azzfox's Avatar
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    all neons iv seen have the converter (inverter increases voltage) which is prob just a resistor built into the neon unit.. anywho its always better to be safe than sorry
    My (ex)Ride
    Keesh's Avatar
    Jan 2006
    yer inverter/transfprmer watevs haha.. um i opened one up it has a lil thermo fuse transformer inside so it must b important i guess:S
    azzfox's Avatar
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    if i diddnt have to take half the roof lining off to cable-tie it back on i would also open it and have a look
    My (ex)Ride
  1. interior/boot light......
    By donsvt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-10-2006, 07:42 PM
  2. Boot Neon and Activation
    By tr3nt in forum Electrical Wiring / Questions
    Last Post: 02-07-2006, 12:37 AM
  3. Neon as extra interior light
    By fitzy2005 in forum Electrical Wiring / Questions
    Last Post: 07-03-2006, 03:34 PM
  4. Interior & Boot Light
    By Agro in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-10-2005, 02:42 PM
  5. Boot Neon
    By Wire in forum Electrical Wiring / Questions
    Last Post: 21-10-2005, 04:00 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
