+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 31
Thread: The Ultimate Tacho Thread
    253@7k is offline 300rwhp supra. yay. 253@7k Executive
    TT Supra/HZ Ute.
    Apr 2006
    Default The Ultimate Tacho Thread
    Ok I have decided to do my own little bit of cleaning, so please take notice before asking "how do I install a tacho?"
    In this thread you will find links to all kinds of info on tachos. Threads have covered:
    How to install tachos,
    Troubleshooting with tachos and
    Why the hell do you need a tacho in the first place?
    These threads should supply you with all the info you need. (And stop the need for more tacho threads)
    Here we go.....
    Finding the "brown wire"
    Wiring tachos (vn onwards)
    Why do you need a tacho arguement
    More wiring solutions (VY)
    Solving problems with your tacho signal
    And these are just some of the ten thousand million that exist.
    So, to conclude:
    VB-VL= signal wire to coil.
    VN-VX= Signal wire is brown wire near strut tower.
    VY V6= Signal wire is solid brown wire in the loom infront of the coil pack.
    VN's have signal problems. (Some dont send correct signal. Fix with tach adapter)
    These should answer just about any questions you may have. If you need to see what I have said repeated 1000 times just do a search on "tacho".
    Just rember, your commodore probably already has a damn tacho.
    Steve.
    azzfox's Avatar
    azzfox is offline slideways azzfox Caprice
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    thankyou, hopfully we wont get anymore tacho threads with questions asked a million times
    My (ex)Ride
    Quote Originally Posted by ari666 View Post
    LMAO!!! bracelets!!! and neck chains?!?!? they are as gay as aids.
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Nice 4 year old thread dig dude....got a permit to mine that deep?
    Goon's Avatar
    Goon is offline VY COMMODORE BABY! Goon Executive
    2004 VY COMMODORE S2/V6. SKYLINE R33 GTR TURBO
    Feb 2006
    GC
    My VC's Speco tacho
    Green to coil
    Red to 12v accessory
    Black to Negative
    White for light, but thats not connected.
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    Pub247's Avatar
    Pub247 is offline Donating Member Pub247 W427 Pub247 W427 Pub247 W427
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    What's involved in recalibrating a tacho eg vh sle v8 tocho down to a 202 would recalibration be needed?
    azzfox's Avatar
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    Quote Originally Posted by Pub24/7
    yes, it will need to be changed to suit the 6cyl. if its a stock tacho im not sure if it can be done. if its aftermarket there should be a switch at the back of the tacho.
    My (ex)Ride
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Goon mine is an actual in dash original tacho like instead of where the vac gauge would be. Slundy can you help me will it need doing or should it be right?
    TT Supra/HZ Ute.
    Apr 2006
    Hmm, for some reason my post did not come up. I'll post it again.
    From what I can tell, changing a v8 tacho to a 6 tacho just requires a resistor in the tacho to be changed. That is as far as I have gotten, I cannot seem to find the exact resistance that is needed. I think we need an elec expert.
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    ok thats cool i havent really looked at it yet and not going to do it yet so i'll pull it apart and have a look
    Tasmaniak's Avatar
    Tasmaniak is offline Not a valid input.... Tasmaniak Executive Tasmaniak Executive Tasmaniak Executive Tasmaniak Executive
    car
    Apr 2005
    Stickied
    Recalibrating a tacho cannot be done via a resistor. Putting in a resistor will stop the tacho altogether. Tachos work on pulses of 12 Volts. So, by putting in a resistor it still pulses just at a lower voltage causing the tacho to stop working at all.
    Check on the back of your dashboard circuitry. You MAY find a little switch
    TT Supra/HZ Ute.
    Apr 2006
    Quote Originally Posted by 12Voltking
    Stickied
    Glad your here to keep us on the strait and narrow, cheers.
    Steve.
    bangers's Avatar
    bangers is offline <<<There's a good present bangers has disabled reputation
    EL FALCON XR6
    Aug 2005
    NSW
    Quote Originally Posted by slundy
    So, to conclude:
    incorrect. the signal wire on a VL does NOT go to the coil! there is a wire behind the instrument cluster. the coil is a multi spark system i believe and will give an incorrect reading. in the Gregory's manual it says there is a signal wire hanging behind the alternator but that is incorrect too, it is only a test wire.
    TT Supra/HZ Ute.
    Apr 2006
    Ah yes bangers, my mistake I forgot about the rb30's. However V8's should still be able to go to the coil though right?
    bangers's Avatar
    EL FALCON XR6
    Aug 2005
    NSW
    i imagine so as the V8 didn't have an ECU. but then like the RB30 the wiring loom may be the same for auto and manual. i can't say for certain.
    Tasmaniak's Avatar
    car
    Apr 2005
    Either way....the wire will always be behind the dash as well....
  15. #15
    Frandy's Avatar
    Frandy is offline _____________ Frandy Executive
    '99 KN Laser 1.6
    Sep 2005
    Diamond Creek Melbourne
    what about installing a stand-alone shift light?? How do you wire one of those up?
  16. #16
    anton1o's Avatar
    anton1o is offline [GMHVN6] anton1o Executive
    VN 6 Berlina '90
    Jan 2005
    West Subs,Melbourne
    Or installing a water temp gauge, oil temp, oil pressure..
    ride; [GMHVN6] Project Streeter - VN Berlina '90 mods; 65mm throttle-body / Cold Air Intake / 8mm Ignition Leads / Exhaust
    future; Extractors , Cam currently; 101.2rwkw mission; 110rwkw
  17. #17
    TT Supra/HZ Ute.
    Apr 2006
    Quote Originally Posted by Frandy View Post
    Read the instructions, there will be a signial wire that will be connected to the same signal wire as your tacho. (see above posts for instructoins on finding wire.)
    Quote Originally Posted by anton1o View Post
    A few questions there. Depends on the car, engine and gauge. more info needed.
  18. #18
    VH Commodore
    Dec 2006
    Thumbs up help me
    can some1 plzzzzz help me?!?!, i got a VH Commodore n im lookin to wire up my tacho but i wouldnt have the faintest idea when it come to wiring n electricals. can some one tell me how to do this in a way that even id be able to understand?? cheers
  19. #19
    Goon's Avatar
    Feb 2006
    GC
    Quote Originally Posted by bobhasnoshoes View Post
    Look at my post above, red will always be postive and black neg, ones lights and the other coil.
  20. #20
    vt executive s1
    Feb 2007
    cheers man im havin big dramas with the tacho i got now i own a vt and im trying to put my speco 4 in 1 tacho in and i have got all gauges to work excep the tacho i have tested the tacho on a different car and the tacho itself works fine and i have tested the tacho off the wiring on the guage cluster in my vt and i cant get it to work any suggestions
  21. #21
    MUNTED6 is offline Banned MUNTED6 Hitchhiker
    vn berlina
    Apr 2007
    that happened to me so i had a spare coil pack in my shed i changed coils and the tacho worked(revs) wen i examined both coil packs the coil that didnt work was missing pins, so may u should try changing coils
  22. #22
    VZ
    Jan 2008
    VY II SS
    Jan 2006
    Warwick
    need help for my autogage monster tacho. which wires do i cut at the back for a v6. theres a orange loop and a brown loop of wire?
    cheers,
  24. #24
    VY Acclaim
    Nov 2006
    VrWagz1's Avatar
    VrWagz1 is offline The Wagon on Wheels.. VrWagz1 Monaro VrWagz1 Monaro
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    I'll add this to this thread as it is the ultimate tacho thread
    How to convert a V6 tacho to suit a V8
    Reaper
+ Reply to Thread
LinkBacks (?)
  1. The Ultimate Happy Man
    By redcedar in forum Jokes/Humour
    Last Post: 17-11-2007, 11:54 AM
  2. Tacho (yes i know there is an ultimate thread)
    By WhiteLightning in forum Electrical Wiring / Questions
    Last Post: 19-04-2007, 11:47 AM
  3. BP Ultimate is the best...
    By veclubby in forum General
    Last Post: 14-01-2007, 04:41 PM
  4. The Ultimate Showdown
    By S Pack in forum Jokes/Humour
    Last Post: 15-09-2006, 03:35 AM
  5. Bp ultimate
    By satos in forum General
    Last Post: 15-12-2005, 10:33 PM
