+ Reply to Thread
Results 1 to 3 of 3
Thread: thermostat and new fan
    VH commodore SL wagon 253
    May 2006
    the shire sydney
    Default thermostat and new fan
    looking around on ebay you can pick up 12-15" fans for damn cheap but not many come with shrouds or thermostats... how hard is it to get a fan on my car without the shroud and whats involved with hooking up the thermostat i could pick one up off ebay by itself or maybe hit up repco...
    really keen to get rid of the clutch fan its so noisy
    Achin' for a v8 wagon people click me!
    maginoodle's Avatar
    maginoodle is offline Donating Member maginoodle Berlina
    vy series2 ss crewman
    Apr 2006
    you should already have a thermostat in your car. You are probably talking about the temp sensor for the thrmo to cut in and out. Depending on what sender you buy, it will be different in the way it hooks up. Some have a little sesor on the end of copper wire that you put into your top radiater hose and some sensors screw into your radiater.
    The shroud is the piece that stops you from putting your fingers into the fan. You shoulnt need one on but some pink slip people want them on. As long as the fan has a housing on it with mounting holes in it it should be easy to mount.
    You dont have to put a temp sensor in(just have a toggle switch or have it on whenever the motors on) but it it easier than trying to remember to turn it on.
    May 2006
    the shire sydney
    ok that gives me some ideas... i might go with the switch idea ill put a post-it note on the steering wheel or something saying (remember the fan!!!)........or something...
+ Reply to Thread
  1. thermostat
    By pr0n in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-02-2007, 06:58 AM
  2. thermostat
    By ab56452001 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-12-2006, 01:14 AM
  3. Thermostat
    By 10000_fists in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-12-2006, 09:53 PM
  4. thermostat
    By slayer in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-10-2006, 09:48 PM
  5. thermostat
    By danz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-09-2005, 07:52 PM
