Results 1 to 7 of 7
Thread: brake light and dash lights fault
    VT Executive
    Aug 2006
    Default brake light and dash lights fault
    i recently installed a new headunit in my 98 Vt commodore,
    all wires were used except the folowing:
    Brown/wht = dimmer in
    Grey = dimmer out
    black/wht = ground (i made a seperate ground)
    Yellow/Black = Phone mute
    now for sum reason my brake lights wont work and also my dash lights dont work, i replaced fuses and they still dont work
    VS UTE
    Jun 2005
    Lennox Head
    Hey i recently had the same problem, the brake and dash lights are on the same circuit. My problem was that the tail light globe was shorting.
    Mitch
    VT Executive
    Aug 2006
    maginoodle's Avatar
    maginoodle is offline Donating Member
    vy series2 ss crewman
    Apr 2006
    pull out your brake light bulbs. and see if the dash lights work. if they do replace the bulbs one at a time until you find the faulty one
    VT Executive
    Aug 2006
    VT Executive
    Aug 2006
    Unhappy
    ok i took all 3 brake bulbs out and replaced fuses, but still the dash light fuse blew and so did the brake fuse when i stepped on the brake.
    is there any other way to check what the problem is or should i just take it to a autoelectrician
    -Junior-'s Avatar
    -Junior- is offline <-- Back to Back in 2010
    vn auto
    Apr 2006
    S.W. Sydney
    May not be but check the wiring harness behind the boot liner on the drivers side near the fuel flap. The wiring may have rubbed through on the sheet metal.
  1. Lvl 3 Dash Conversion Problem: H/Brake Light comes on while driving.
    By nugatory in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-10-2007, 06:26 PM
  2. brake = dash lights comming on?
    By H.I.M666 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-12-2006, 12:16 PM
  3. help urgently!!! i have no brake or dash lights
    By VXII_S_smokin in forum Electrical Wiring / Questions
    Last Post: 20-05-2006, 10:42 AM
  4. help urgently!!! i have no brake or dash lights
    By VXII_S_smokin in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-05-2006, 10:22 AM
  5. my dash lights up when i touch the brake!!
    By sweet_vt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-01-2006, 12:56 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
