Results 1 to 13 of 13
Thread: vp wiring diagram
    Matt_vp's Avatar
    Matt_vp is offline Donating Member
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    Default vp wiring diagram
    does anyone have a wiring diagram for a vp 92 model that they can email me or post on here
    regards matt
    94 vr 5sp, 04 vz wagon,82 vh V6 wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    Which part of the wiring did you want?
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
    Matt_vp's Avatar
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    im have a problem where the car will just shut off and when i try to start it the check engine light doesn't come on, but if i arc the 12 volt pin on the dionostic link with the one that goes to the fuel pump a few times with the ignition turned to on the check engine light will come on and the car will start. so i need the a digram with the check engine light, the fuel pump and the computer i guess.
    Nov 2003
    northside brisbane
    Heres the ecu diagram that takes in that part
    The check engine light is fed a negative by the ecu to it to make it light in the cluster.
    Attached Thumbnails Attached Thumbnails vp wiring diagram-ecm-v6.jpg   vp wiring diagram-ecu.jpg   vp wiring diagram-ecu2.jpg
    Matt_vp's Avatar
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    Thanks for that mate but can i trouble you to post the other half aswell.
    Nov 2003
    northside brisbane
    Ive added the whole page to my previous post...you will have to join the 3 pages together.
    Matt_vp's Avatar
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    thanks hopefully i can work this problem out now.
    Where do you get those wiring diagrams from?
    Thanks Matt
    VP MANUAL S/C 3.8 UTE
    Nov 2006
    Country Vic
    sorry to dig up a old thread but did you happen to work out what was wrong as i have exactlly the same problem with my vp at the moment
    Quote Originally Posted by HoZy View Post
    Please insert your keys into your rectum an sell the car for scrap...
    Regards Mathew
    Ek wagon 0-60mph 6.19 20/4/07 G-Tech so there is no cheating 1/8th mile @ mph Unknown , estimated 1/4 mile Unknown
    www.unleashedpleasures.com.au My new adult toy site
    Nov 2006
    Country Vic
    or anybody else that is good with electrics have any idea on what could be wrong??
    Regards Mathew
    Nov 2006
    Country Vic
    took it to a auto elec today and when i went to pick it up he said he could not find the fault
    anybody got any ideas at all i have replaced the computer and memcal tried removing the efi relay to let it reset its self and still end up with the same result
    many thanks in advance
    Regards Mathew
    Matt_vp's Avatar
    vy lumina v6 A4
    Jan 2006
    Gladstone Qld
    does it do the same thing when u arc between the 2 terminals on the dionostic link,
    mine just went away really amonst replacing heaps of parts, i would start with relays, dfi module, coilpacks, fuel pump.
    also have a look at the wiring in the dfi plug and in to the ecu.
    good luck mate and i feel for u it sucks
    Matt
    Never tell your problems to anyone...20% don't care and the other 80% are glad you have them.
    - Lou Holtz
    Found my reply helpfull? Share the love and click the star down the bottom
    Nov 2006
    Country Vic
    Yeah when i link across the diagonstic plug for the fuel pump it will eventually fire after about 25 to 30 seconds of cranking, the dash/warning lights will flick on and as soon as that happens it fires straight away
    the things i have replaced so far is the computer, memcal, relays, anti theft module and switch and ignition barrel. checked all fuses and none were blown
    I think i might rip out the wiring loom and put a vr 1 in as i have all the parts to convert it
    most frustrating problem i have had so far.
    Regards Mathew
    VU SS UTE / 5 Litre Volvo /Trusty Swift
    May 2008
    Penrith NSW
    Mate just a guess but my mates VR had the same problem after 10 times at the auto electrician all it was is the water sensor was faulty.. Not sure what its called but you have a sensor that will kill the motor if there is no water and after replacing it not a problem since..
    Hope it helps..
  1. VN -VT V8 Wiring Diagram
    By RobTheInventor in forum Electrical Wiring / Questions
    Last Post: 18-02-2007, 10:22 AM
  2. wiring diagram for VP
    By macca2069 in forum Electrical Wiring / Questions
    Last Post: 30-01-2007, 02:05 PM
  3. VR Wiring Diagram
    By ptal in forum Electrical Wiring / Questions
    Last Post: 15-10-2006, 10:31 AM
  4. VZ V8 LS1 Wiring Diagram
    By markll in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 08-03-2006, 12:31 PM
  5. vn wiring diagram
    By chevy_big_block_bro in forum Electrical Wiring / Questions
    Last Post: 26-01-2006, 07:08 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
