Okay been doing some research on this just need to double check with you guys.
1994 used the 16176424 ECM for the auto cars.
I found the $11 ECU on moates fileman website (although it has some issue with the checksum.
I have also found a PROM BIN BMZA1754 41 Not sure if this is the one to use. But I don't really need it I would like to leave the car untouched for now I would rather firstly like to do some data logs.
The only thing I am missing is the ADS file for tunerpro to hook up to the laptop. Does anyone have this Data Stream file or know where I can download it from?
If anyone can help out that would be awesome!
Do a search for memcals and greenfoam, you will find that he has a VR file on here somewhere with the bin and xdf file.
Illegitimi Non Carborundum
I have searched and I cant seem to find anythingHopefully greenfoam sees the post and might help out.
Knowing my luck the ADS will be for a manual VR which uses a different PCM.
Keep my fingers crossed.
By the way I have the XDF and BIN. I don't really need them i need the ADS to be able to datalog with tunerpro. I can copy my original EPROM if I want. But at the moment I just need to be able to datalog this 1994 VR 3.8L auto V6
I only have the ads for the manual one, but the efilive one says it does both so you should be able to make one from that
http://www.efilive.com/download_V4xml/gmh-vr68vs8.zip
Thanks guys, but I had no luck getting a connection. I tried EFI live and it did not show any values. Kept on getting ECM override messages. I am also not very familiar with that program as I use TunerPro.
Might have to ask what people are using for this car as dattalogging.
Hi Guys
I don't know if you can help me but i am chasing the wiring diagrahms for a VR V6 Auto ecu ( wiring plugs) both on the input & output side,,,, any help would be appreciated
Mal
