Results 1 to 3 of 3
Thread: Cigarette lighter in VT
    Dec 2006
    Default Cigarette lighter in VT
    My cigarette lighter has broken off or otherwise come loose behind the panel.
    Could somone please advise how I get in to it so I can fix it?? I have taken a few panels off down the side where your feet go, but I can get my hand in there..
    cheers
    Phil
    Vx SS Gen III
    Nov 2006
    Northen Subs Melbourne
    Gday Mate Just Take the Gear Souround Panel off gently lift it up & near the lighter there is a rubber mat take that out and u will see two screws undo them both now remove the panel Then u can fix your ciggy lighter !
    v6 vt 2000
    Jul 2011
    nelson nz
    Default cigarette lighter VT commodore
    year that's it take the little rubber tray out you will see two screws undo them lift gentle between the back of the gear shift and the electric window switches takes a bit of ma-nova two get it out. and take the wires off the window switches carefully you will see your ciggy lighter the nut unusually falls of the back put back together the same way take your time you shouldn't break anything good luck
  1. Cigarette Lighter illumination
    By COWSPUD in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-04-2010, 08:03 PM
  2. cigarette lighter fus
    By vg91ute in forum Electrical Wiring / Questions
    Last Post: 02-01-2008, 08:12 PM
  3. Cigarette Lighter
    By vs_commodore_guy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-07-2006, 03:54 PM
  4. Cigarette lighter not working
    By killuminati in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-04-2006, 05:44 PM
  5. cigarette lighter not working
    By ucwepn in forum VL Holden Commodore (1986 - 1988)
    Last Post: 11-08-2005, 08:43 PM
