im wiring in a set of spotties to my vx commodore (2001) and im having trouble getting the wire for the high beams... as the spotties need to be on the dipswitch. can anyone help with this??? the wire colour for the high beams on the plug on the headlights?
Hi Donkeey,
Attached picture is from a Gregorys manual. Looks to me Like X (light Green). Hope this helps.
Use the two pins on the outside of the headlight H4 globe to switch the 85 & 86 pins on your relay, to have a isolation switch inside, cut 1 of these wires and put a switch inline to isolate the circuit.
This would be the easiest way for a DIY, holden switch an earth to the headlights, so could make it harder for you, but the above method is easy.
Make sure you use a relay and decent size wires.
