just trying to fit a water temp gauge to my vr v6, and was wondering if there is a wire behind the dash that i can tap into to pick up a temp. if not how would i hook it up?
thanks in advance
no you will have to use the sender that should have come with the gauge and run a t-peice from the factory gauge sender located at the front of the engine near thermostat, or remove the factory guage sender completely and only run your guage from that, you may/may not need appropriate thread reducers etc so it all fits up...
