Results 1 to 2 of 2
Thread: Wiring diagram for VY berlina wagon
    VY Berlina Wagon
    Mar 2007
    Default Wiring diagram for VY berlina wagon
    Hi Guys,
    I am looking for a Wiring diagram for VY berlina wagon so I can work out how to install an addon alarm with back up batt, shock sensor and such, that uses the original keys buttons and works with the factory locks, immoblizer, alarm setup
    Peter
    Apr 2007
    This is from a 2002 - 2003 VY commodore I do suggest testing your wires before you connect anything,
    All of these wires are located at the BCM, The BCm is under the Drivers side dash near the fuse box.
    Ignition * Orange wire from BCM, plug X3
    Ground * Black/Green trace wire from BCM, plug X1
    +12V * Orange/Purple trace wire from BCM, plug X1
    Lock Trigger * Brown/White trace wire from BCM, plug X4
    Unlock Trigger* Light Green & yellow, Brown & Orange From BCM, plug X4 (Diodes are required)
    Bonnet * Yellow/Black trace wire from BCM, plug X3
    Boot Release Sense *Red/Green trace wire from BCM,plug X4
    Actuator Lock Power *Black/Yellow trace wire from BCM, plug X4
    -Door* Grey White & White Wire fom BCM, plug X4 (Diodes Are Required)
    Actuator Unlock Power *Blue/Black trace wire from BCM, plug X4
    Indicator * Blue wire from BCM, plug X1
    Indicator * Lite Blue wire from BCM, plug X1
    Hope this helps you out... Upgrades and be wuite dificult. But hope all goes well for ya
  1. VS wiring diagram
    By vsiicalais in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-11-2007, 04:38 PM
  2. vr berlina wiring diagram needed, climat control problem
    By vrberlina5sdp in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-08-2006, 09:20 PM
  3. VL wiring diagram
    By 82VH in forum VL Holden Commodore (1986 - 1988)
    Last Post: 25-10-2005, 10:21 PM
  4. Wiring diagram
    By morgan-mog in forum Electrical Wiring / Questions
    Last Post: 15-06-2005, 12:38 PM
  5. Vy Wiring Diagram
    By grumpster in forum VY Holden Commodore (2002 - 2004)
    Last Post: 01-03-2004, 12:37 AM
