You should put them in each pipe before they go into a single before the turbo as they need to read the O2 ratio from each bank.
Hi guys,
I am currently turboing my VS commodore with a single turbo setup. I have neerly finished and I am just working out what I am going to do with my 02 sensors. being an ecotec I have 2x 02 sensors, one for each side but being that I have a turbo I will need to put these into the dump pipe so I was wondering can I just stick one 02 sensor in the dump pipe and then wire the 2nd 02 sensor wires into the first one. Or what do you guys sugest.
ummm.. would it handle the heat? those manifolds will be glowing hot...
