Results 1 to 3 of 3
Thread: Horn In a VL
    VT SS 5.0
    Oct 2004
    Seaford, Melbourne
    Default Horn In a VL
    Hi horn isnt working in VL, how would I fix this? Press the button and it no workie..
    THanks
    Bax
    Bax is offline Projecting
    Nothing
    Jan 2004
    QLD
    Take the wheel off and earth the connection yourself. If not, maybe your horns dead.. I spose you could give it power directly if you wanted to stuff around.. But yeah, check the switch behind the steering wheel first.
    Stock wheel, to take off you pull off the horn pad and backing plate.. Should be able to see it from there... But for more experimenting undo the bolt til its nearly off, pull hard on the wheel until it pops off.. undo the bolt, take the wheel off and fiddle with the wires..
    Aftermarket wheel: Well, same thing basically.
    VT SS 5.0
    Oct 2004
    Seaford, Melbourne
    Cheers will give it a go
  1. Replies: 3
    Last Post: 03-02-2007, 08:51 PM
  2. horn
    By slayer in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-01-2007, 11:56 AM
  3. Horn
    By SUSPECT in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 18-02-2006, 12:21 PM
  4. VN Horn Pad
    By R Photon in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-12-2005, 06:18 PM
  5. Horn
    By VXWAGMAN in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-05-2004, 12:28 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
