does any one kno how to fix this problem ?? i didnt realise untill it was to late and the light had drained my battery...
Maybe the switch is dodgy. Have a look on the driverside boot hinge back up where it mounts in the boot, you'll see the switch up there somewhere...maybe push it in and out a few times and spray some wd40 on it to lube it up. That's the only thing I can think of as to why the light would stay on.
VK Wagz 308 - [Buildup Thread]
VK Wagz 253 Twin Turbo - [Buildup Thread]
VK Wagz EFI 5.0L 5spd - [Buildup Thread]
TECH: VK EFI Conversion - Fix your dead EFI 5L ignition module - Trimatic shift kit
Would have to be a faulty switch. Try lubricating it or cleaning it with contact cleaner, as suggested above, or go a new switch. Failing that it is possible the bulb connector is grounding and bypassing the switch. Definatly try the first though, much more likely.
thanks guys, you were right cane_it just had to bend it back and its all good now. cheers again
