+ Reply to Thread
Results 1 to 9 of 9
Thread: Complete guide to nokia CK-7W install in VY/VZ.
    Feb 2004
    Default Complete guide to nokia CK-7W install in VY/VZ.
    All,
    I have been trawling through the forums on nokia CK-7W car kit install.
    I can not find a step by step guide for this.
    I understand the basic install process but what other parts are needed other than the nokia package? ie pin connectors etc?
    If someone could give me some help it would be appreciated...
    Thanks for your help.
    Brad.
    08 VE SSV M6
    Dec 2005
    These are the bits you need and what pin is what:
    The 6 way connector socket can be located under the passenger side of the centre console. The plug to fit this socket can be sourced from your local Holden Dealer for under $5 all up. Part numbers as follows:
    92143075 - Connector-Phone
    (This is the plastic plug assembly; you will need 1 of these)
    92141210 - Terminal-Phone
    (These are the actual metal solder/crimp pins; you will need 6 of these for a full installation... funny that Holden seem to pack them in lots of 5? )
    The 6 wires are as follows...
    Orange - 12V Supply (Battery via fuse... always on)
    Black/Green - 0V (Chassis, earth, ground... you know the drill)
    Yellow - 12V Accessory Supply
    Yellow w/stripe - Radio Mute signal. Active Low.
    Blue w/stripe - Audio-
    Blue - Audio +
    Feb 2004
    thanks mate, much appreciated...
    Few more questions:
    1. Will this method use the car speakers when on a call? if so do I still need to install the Nokia supplied speaker?
    2. Will this method allow me to use the steering wheel volume controls?
    3. I notice that the plug is 6pin. On the Nokia manual it shows the cable set as 4pin. Is this correct, are there 2 pins not used?
    4. Other than installing the box, mic, cradle, and connecting the wire from the nokia box to the holden 6pin adapter is there any other things to know?
    thanks,
    Brad.
    08 VE SSV M6
    Dec 2005
    Quote Originally Posted by bradwilks80 View Post
    Few more questions:
    thanks,
    Brad.
    1. Yes, the call will go through your car speakers. No, chop the speaker off and connect it to the audio + and - as labled in the above post.
    2. Yes and mute will still work
    3. When you include the two speaker wires that will make 6 total.
    4. No not really, it is really that straight forward. I had the mic above the rear view mirror then ran it down the left A pillar, behind glovebox to back of the stereo (where I velcroed the Nokia box in). You can also put the mic on the drivers A pillar, which is where the genuine holden instructions say to mount it. I didn't use a cradle as I had a bluetooth phone. I left the pop port cable tucked up under the trim in the passengers footwell if my phone ever really needed a charge, but very rarely did I use it. I mounted the remote on the centre console behind the window switches (had a ute so only had to switches and a big blank area behind it)
    Any other questions then give me a yell...
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    When Idid it I got a factory cradle attachment that goes on the side of the console so you dont have to drill any holes in it .Also there is a factory switch that goes in the console with a phone symbol on it that you can wire in to make it look complete instead of the loose nokia one but that will only be useful if you intend using bluetooth.
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
    Atreidae is offline (Was an) Installer Atreidae Executive
    VN Calais
    Oct 2005
    best place to hide stuff.
    Wire up the nokia as said before.
    Red on nokia to orange on phone plug
    blue on nokia to yellow on phone plug
    yellow on nokia to yellow blue on phone plug
    Black on nokia to green/black on phone plug (or the earth screw)
    (not yellow to yellow, you will get a nice melty smell if you do!)
    Open the console under the steering wheel.
    remove screw on top left size near the computer controls. stick "nokia" button down and left of the computer buttons (best place)
    pull plastic back (where you removed the screw) and thread cable from nokia button
    replace screw
    remove two lower left screws on right side of console
    run wire from button to other side of tunnel
    place speaker behind panel, cable tie to metal pole run cable over tunnel
    Cut the speaker wire about 4-5 inches from the plug end, strip both ends, join red to red and black to black, now splice into the blue wires., red to blue black to blue black
    this way the speaker works even when the radio is off, (fuse blown) or not muted
    databox goes in behind the wite drain on right side of tunnel.
    ill do a real guide one day.
    I am to 12voltking as Jesus was to God.
    VN Calais
    Oct 2005
    damn, I didnt realise this was such and old thread.
    VP Executive Wagon
    Feb 2005
    Thumbs up Holden Mobile Phone Mounting Platform - Part number 92144493
    Quote Originally Posted by markovr View Post
    ...factory cradle attachment that goes on the side of the console so you dont have to drill any holes in it ...
    Thanks for the tip. My local Holden dealer still has the "Mobile Phone Mounting Platform" on their shelves. A quality made plastic bracket. Holden part number 92144493. Cost $28 in March '10.
    I would recommend it. See attached for a diagram of the mounting.
    Enjoy.
    Attached Thumbnails Attached Thumbnails Complete guide to nokia CK-7W install in VY/VZ.-holden-mobile-phone-mounting-platform-92144493-2.jpg
    VZ Executive
    Apr 2009
    Has anybody successfully installed a Nokia CK-100 in their (VY/VZ?) Commodore instead of the tried and true CK-7W? i hear that it has better echo cancellation for non-nokia phones (I have an iPhone) and they're not much more expensive on fleabay at the moment..
+ Reply to Thread
LinkBacks (?)
  1. Replies: 82
    Last Post: 18-07-2010, 03:17 PM
  2. Guide to New Lead Install For VN SS 5.0L
    By RVN 355 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-04-2009, 08:45 PM
  3. has anyone made an amp install guide for vn?
    By beefcream in forum Car Audio
    Last Post: 15-04-2006, 11:20 AM
  4. Complete ALDL Guide For VN-VP (.html link)
    By azzfox in forum Holden Commodore How-To's
    Last Post: 15-03-2006, 04:01 PM
  5. Subwoofer Sealed Enclosure Install Guide
    By Kersh in forum Car Audio
    Last Post: 22-10-2005, 11:20 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79
