I have a VY S Commodore ute fitted with an SS bodykit, including foglights, and the headlight / foglight switch.
Does anyone know how to make the indicator appear on the trip computer when the fog lights are on??
As far as I know, there is no fog light indicator in the trip computer.
The only indicator is in the dash cluster, toward the bottom right. It's a foglight symbol lit by an LED from behind.
Thanks for that mate.
I bought the Ute privately, and the guy had the SS kit and foglights fitted by some oufit.
Looks like I will have a bit of fun hunting for the wiring to make the indicator light up - the way it should.
it needs an input into the cluster at pin 9 & i think the tell tale needs to be enabled in the programming.
Rob
Now I am a little confused!
Is the fog light indicator displayed on the trip computer window, or is it a dash light?
I have looked at my dash cluster and there is definately no indicator light - I can see all the other ones - battery, setabelts etc.
I am not sure if i will have to upgrade the entire cluster or not (to HSV / SS) just to get a fog light indicator.
Any words of wisdom would be much appreciated.
Andy
theres a telltale on the dash as davey said, not sure what you mean by trip computer display, i think you mean the multi function display (MFD) in the centre of the dash, theres nothing in this i dont think?
Rob
Na, there's nothing in the MFD, just the LED dash light.
I have just sold my police issue sv6 vy 2003. But before i did i pulled the whole dash apart because i had it recoated black (instead of the gray colour).
i had to take the dash cluster out because there was a grey plastic bit in there too.
When i did i noticed that the fog lamp led was working but you could not see it becuase it is covered behind the dash insert -a piece of plastic which has the ss or sv8 logo and all the speed numbers printed on it.ie 0-240kph and rev's etc.
i'm guessing that the ss version of the dash insert doen't cover up the led for the fog lamps so you see it.
see JHP Vehicle Enhancements - Specialise in Holden Monaro and Commodore Spoilers, Body Kits, Tyre and Wheel Packages.
