+ Reply to Thread
Results 1 to 7 of 7
Thread: beeping in the cluster
    slipstream001 is offline -=Slipstream=- slipstream001 Executive
    VR Senator II
    Jan 2007
    Werribee, Victoria
    Default beeping in the cluster
    hi all, I really need some help with my 92 VP Calais, for a while now every 60 odd seconds there's a beeping from the cluster which is the sound of either the handbrake being on or the car overheating, neither of these are actually happening, the car isn't hot and the handbrake is off. I'm really stumped as to what it could be. any help or suggestions would be muchly appreciated as its really annoying.
    thanks heaps slipstream
    88GreenVN's Avatar
    88GreenVN is offline Almost not here! 88GreenVN W427 88GreenVN W427 88GreenVN W427 88GreenVN W427
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Quote Originally Posted by slipstream001 View Post
    Pull the chime out. Thats the simple fix.
    The low fuel and over speed are the other 2 reasons for it to chime in the VP.
    Also the type of signal may hint as to whats wrong. (long beep short beep.)
    and 3 Dangerous non ABS VN's
    VR Senator II
    Jan 2007
    Werribee, Victoria
    VY V6 Acclaim Wagon
    Dec 2006
    88GreenVN's Avatar
    Jun 2006
    its three short beeps, which is the chime for overtemp or handbrake on
    If your not getting any overheating codes from the ECU (faulty temp sensor) then it most likely be the handbrake circuit.
    You may need to pull the cluster out and check the wires/circuits with one of those multi meter thingos.
    Dose the handbrake light stay on (drive off with it on the first click) and the cluster chime away?
    I'd pull the chime out. I have a spare chime sitting on my bench in the shed. (yep unwanted chimes every time I drove the car)
    VN v6 s2 Berlina 5spd
    Mar 2006
    hey mate,
    i had the same thing happen in my car,
    every time i took off or got past 40 it would beep,
    i had a broken handbrake light globe,
    i suggest you check all your globes first
    i replaced my handbrake light and it was fixed.
    good luck
    VY SV8 HBD---mmmm LS1
    Simon Champion! On The Volley Champion! Shootin Hoops Champion! Batting Champ Champion!
    Dec 2005
    Western Suburbs
    hmm mines doing this just today except my does it when im breaking or slowly taking off evey now and then sounds like handbrake chime but theres no light coming on when i got home turned car off then on light came back on and stopped beeping?
+ Reply to Thread
  1. VY Horn Beeping on Locking
    By Secki in forum VY Holden Commodore (2002 - 2004)
    Last Post: 21-12-2007, 12:25 AM
  2. Stupid Beeping!!
    By frenzal_tom in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-11-2007, 03:05 PM
  3. Beeping with new installed cd player
    By damez in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-07-2006, 12:25 AM
  4. How do I fix the handbrake beeping on my new cluster
    By gdunkley84 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-01-2006, 06:02 PM
  5. vl beeping?
    By sully in forum VL Holden Commodore (1986 - 1988)
    Last Post: 01-03-2005, 03:15 PM
