6h84eva
Certifiably Holden Mad
- Sep 3, 2004
- 38
- 0
- 0
- Age
- 54
- Location
- Conifer Grove, Auckland, NZ
- Website
- www.ithome.net.nz
- 2004 VZ SV6
Got a VSII Berlina that will periodically have an issue with the instrument cluster.
Driving along, the LCD screens go back to the state the car is in when the ignition is off (ie: nothing in the middle or left screen and the odo reading in the right hand one) and then will go back to reading everything as normal, but the fuel, overspeed and water temp lights are flashing.
Note: on a VSII, these three lights are the first ones to go out when the ignition key is first switched on before starting the engine.
There is no drop in power, the engine stays running and powers along as normal, the lights are on fine, all the gauges stay working - just the LCD goes back to 'off' state, then comes back on with those three lights flashing below it. Makes no difference what is turned on or off or whether I'm accelerating or decelerating.
Has started this today. Anyone struck it before?
