+ Reply to Thread
Results 1 to 6 of 6
Thread: Aldl Software?
    Dev1lman Guest
    Does anyone out there have or know of any *decent* aldl software?
    OSL-060's Avatar
    OSL-060 is offline Banned OSL-060 Executive
    Dec 2003
    SE QLD
    Even if you could get it (which you can) and hook up the ALDL connector with a 10 k resistor. The Vehicle service mode information isnt really interesting anyway. It spits out things like RPM, MAP sensor voltage, TPS Voltage, Manifold Air Temps, Coolant sensor temps, Injector flow rate and duty cycle etc etc etc.
    Kalmaker software is what you need to really play with the ECU and a good knowledge of EPROM's, burning and all the other stuff I know nothing about
    Jake.
    bizzo Guest
    Feb 2004
    QUOTE (bizzo @ Jan 18 2004, 11:03 PM)Where can i buy ALDL connectors from?
    I've come across a connector that mates up perfectly with the ALDL connector present in the VN-VP(early) female connector.
    Its part of a stereo harness that suits a Toyota Camry 87-94. Worth about $15-20 and is commonly available at Marlows, SuperCheap Auto, etc,..
    The details are:
    - Manufacturer: AERPRO
    - MODEL: APP0141
    All that's needed is to populate the pins to suit the Commodore. There's two connectors supplied in the harness, one is suitable the other can be scavenged to populate the 1st.
    Info may be useful to those wishing to make a cable, etc,.. To easily plug straight in to monitor their Commodore.
    Cheers,
    Jim.....
    Nov 2003
    QUOTE (Jimbo @ Feb 3 2004, 10:36 PM) Info may be useful to those wishing to make a cable, etc,.. To easily plug straight in to monitor their Commodore.
    Whats the monitoring done by ?? Is it plugged str8 into a laptop ?? which I would assume it would need some software installed as well ??
    Feb 2004
    QUOTE (Locksmiff @ Feb 8 2004, 09:51 AM)Whats the monitoring done by ?? Is it plugged str8 into a laptop ?? which I would assume it would need some software installed as well ??
    Locky,
    Never done it,... I got the connector last summer and was planning to have a play but alas got sidetracked with many other things.
    I imagine in 'normal' mode there'd be some data spat out in a serial stream which you could look at. Here's a site I was looking at last time: http://www.techedge.com.au/vehicle/aldl160/aldl_sw.htm, which I think is a pretty common starting point to those with similar thoughts. Seems like with the right definition file you could capture data straight to file that you could upload into eXel to analyze?
    The cable virtually goes straight into a serial port of a computer/laptop, its described here http://www.techedge.com.au/vehicle/aldl160/aldl_hw.htm - a few additional components are required.
    Jim.....
+ Reply to Thread
  1. VR V8 scanning software
    By VRdrift in forum Electrical Wiring / Questions
    Last Post: 29-01-2007, 09:19 PM
  2. New ECU software 172 or 175?
    By old holden v8 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 03-01-2007, 08:57 AM
  3. 160 baud 1227808 aldl software??????????????????
    By CSL in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-11-2006, 10:57 PM
  4. GPS but no software
    By zeb00 in forum General
    Last Post: 12-10-2006, 09:26 PM
  5. Ecu - Pcm Software Version
    By Phil in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-12-2003, 09:37 PM
