Results 1 to 3 of 3
Thread: vs gts 6 speed manual wiring diagram needed PLZ HELP
    Mar 2005
    Default vs gts 6 speed manual wiring diagram needed PLZ HELP
    Hey guys im after a wiring diagram for a vs 6 speed
    These came out in the VS GTS... maybe in the clubbys not sure.. but its not the VT 6 speed is a different wiring diagram
    If any1 has this diagram for a VS V8 6 speed manual plz post
    and if you do have a VS GTS with a 6 speed manual or even a VS with a 6 speed manual in it plz reply aswell as i might have a deal for you
    CHRIS.PORTELLI.VP Guest
    Cool
    SORRY BUDDY I CANNOT HELP YOU WITH A WIRING DIAGRAM I HAVE SEARCHED AUSTRALIA WIDE I EVEN HAVE CONNECTIONS WITH PEOPLE AT GMH AND THEY CANT EVEN HELP. I AM DOING THE SAME THING AS YOU I AM PUTTING A 6 SPEED IN MY VS SS WHICH WAS ORIGINALY AN AUTO 5.0 AND NOW HAS THE 5.7 6 SPEED OUT OF A VR GTS. I HAVE WORKED OUT MOST OF THE THINGS TO GET IT GOING IN A VS, NOW FROM WHAT I HAVE HEARED YOU CAN USE YOUR AUTO ECU (COMPUTER) THE ORIGINAL V8 BAY LOOM WHICH WILL NEED A FEW MODS.NOW THE WAY I SEE IT IM NOT GONNA RUN THE CLUTCH SENSOR OR THE TEMP SENSOR AT ALL. IF YOUR VS WAS AUTO, UNDER THE CONSOLE THERE IS A 4 PIN PLUGIN WHICH YOU WILL NEED TO JOIN THE GREY AND BLACK TOGETHER WHICH WAS THE NEUTRAL SAFETY SWITCH SO YOU CAN NOW START THE CAR AND THE OTHER 2 REMANDING WIRES YOU WILL NEED TO RUN TO THE 6 SPEED WHICH WILL BE YOUR REVERSE. THIS IS ALL I THINK THAT YOU WILL NEED TO START AND DRIVE EXCEPT YOU WILL HAVE NO SPEEDO YET WHICH I AM STILL TRYING TO WORK OUT AND I ALMOST HAVE IT. IF YOU REQUIRE ANY MORE INFO PLZ CALL AFTER 2.30 pm AS I DO NIGHT SHIFT ON 0403477287 ASK FOR CHRIS AND IF YOU WANT SMS ME YOUR NAME AND No SO IF I OR YOU OR ANYBODY GETS ANY NEW INFO WE CAN PASS IT ON TO EACHOTHER OR I AM USUALLY ONLINE MON TO FRI 11.00pm-6.00am YOU CAN FOWARD ANY THING TO ME AT CHRIS.PORTELLI@AU.NESTLE.COM GOOD LUCK CHAMP.
    VS HSV GTS Guest
    i have vs gts 6 speed. i dont have the diagram u should be able to order it thru a hsv dealer. where u at?
  1. Wiring diagram needed for VS low series BCM.
    By Com_VC in forum Electrical Wiring / Questions
    Last Post: 05-12-2008, 10:44 PM
  2. urgently needed auto - manual vs wiring diagram
    By micvs in forum Electrical Wiring / Questions
    Last Post: 14-01-2007, 07:41 PM
  3. VK Wiring Diagram needed
    By lenie33 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 23-09-2006, 09:12 PM
  4. wiring diagram needed for a 92 commodore
    By TrevorAB in forum Electrical Wiring / Questions
    Last Post: 09-06-2006, 08:54 PM
  5. vs gts 6 speed manual wiring diagram needed PLZ HELP
    By Horze in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-03-2005, 11:07 AM
