Results 1 to 2 of 2
Thread: Fuse 10, VS
    2002 WH II Statesman
    Nov 2007
    Knox
    Default Fuse 10, VS
    Anyone have any idea why a VS Berlina would be blowing fuse # 10 (instrument lighting, ignition system) ONLY when the air conditioner is on? Doesn't blow it immediately, takes a couple of minutes. Car has climate control, does not blow any other fuses. I seem to remember it starting when we replaced the ignition leads.
    I survived through summer without the ac.. thought winter would be fine.. until i realised i needed the ac for the demister. sigh.
    Any ideas?
    VRII Acclaim
    Jul 2005
    Fuse 10 is actually a fairly busy little fuse. It wont have anything to do with the ignition leads, unless you bumped an associated wire while you were pulling the leads off.
    Fuse 10 provides power to your heated rear window, as you found out. Try removing the heated rear window (a.k.a rear demister) relay and see if the fuse still blows. You could also try disconnecting the connector off the back of the rear demister switch, as a shorted switch would also cause the problem (do the berlinas have a switch for the rear window demister or is it done through the climate control?)
    Anyway start with that rear demister relay. Its inside the car, second from the left. Pull the relay out and use another in its place.
    If the demister wires shorted out you could also blow the fuse, but it would be fairly hard for those rear demister wires to go short circuit.
    Let us know how that relay goes.
  1. VT Fuse Box
    By sbt in forum Electrical Wiring / Questions
    Last Post: 20-02-2012, 05:59 PM
  2. VR Fuse Map
    By Bryzee in forum Electrical Wiring / Questions
    Last Post: 22-10-2007, 06:11 PM
  3. What fuse does what?
    By Warooda in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-09-2005, 05:03 PM
  4. Fuse Box
    By Hgprem01 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-07-2005, 09:35 AM
  5. fuse box
    By Davin VP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-05-2005, 11:20 PM
