Hey guys,
My brother has just put a 308 into his 4wd, the engine came out of a commodore (VH or something similar) and he also took the radiator with it.
the problem is, the original clutch driven cooling fan doesnt fit with the engine clearance (or some other reason) so he needs to put a thermo fan in it...
My question is... what can he get a thermo fan off, that will have no (or minimal) problems installing...?
is there anything out there that is a straight bolt on? can it be sourced from a wreckers? etc....
any help would be awesome!
mark.
The VT twin thermos will work, but im unsure how much of a straight bolt in they will be, but if you check out the VN aero project site Project VN AERO. You may get some ideas to think about from his conversion. You can atleats use his idea for the fan controller.
