Register - Members List - Calendar - Mark Forums Read -
Go Back   Just Commodores > Holden Commodore Related > Electrical Wiring / Questions
Electrical Wiring / Questions Ask or discuss anything relating to Electrical wiring for your car in here.
Reply
LinkBack Thread Tools Display Modes
  #1
Old 14-06-2008, 08:32 PM
Wavez's Avatar
Ride: VR Berlina M5, VL SL
Trade Rating: (0)
Wavez Executive
Default Upgrading Alternator wire...
Gday just wondering how would I go about upgrading my alternator positive reg wire on my VR. It's the white one that runs from the top of the alternator from the regulator to the positive on the battery...(small white one going from the plug)
Is there a way to remove it from the brown plug? I've tried pinching the wire tabs but cant get to to come through...What is the best way to do this? Would 8 gauge be too big for replacement? The wire is perished (showing the wire through the outer shell) So I thought I would just upgrade it to something larger to fix my lights dimming and charge the battery more efficiently etc... It really just seems too small. oh and what does the big red one on the back do???
Any thoughts are great.
Cheers.
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Google Bookmark this Post!Yahoo Bookmark this Post!Bookmark to AskJeeves!Bookmark to Slashdot!Live Bookmark this Post!Spurl this Post!Reddit! Wong this Post!
Sponsored Links
  #2
Old 15-06-2008, 02:26 PM
Wavez's Avatar
Trade Rating: (0)
Wavez Executive
No one has done it? How can I get the white wire out of the brown plug???
  #3
Old 15-06-2008, 02:32 PM
Ride: 2007 SVZ Wagon
Trade Rating: (0)
Benboy Berlina
If you can't remove the plug easily, I'd cut the wire and take the whole lot to an Auto Electrician and get replacement wire and plug. Reckon that's the easiest, quickets and neatest way out.
  #4
Old 15-06-2008, 02:37 PM
Wavez's Avatar
Trade Rating: (0)
Wavez Executive
yeah I can disconnect the plug from the alternator but can't disconnect the charge wire from the plug...it just wont pull through. I would rather do it myself...
  #5
Old 15-06-2008, 02:51 PM
immortality's Avatar
crappy ol' VN driver
Ride: VN3.8 5spd/VSII3.8/VH5.0
Trade Rating: (0)
immortality Malooimmortality Maloo
i beleive that wire only senses the voltage in the main circuit for the regulator to decide on the output of the alternator. the big red cable is the actual cable that carries the power from the altenator to the battery.
i actually traced out that white wire through my sapre loom a littlw while ago, it takes a hell tour around the loom. a shorter wire wouldn't hurt it i'm sure
__________________
Body by Holden, Soul by Brock
the Legend will live forever
quote of the week
Quote:
Originally Posted by VT-565 View Post
why don't you want to go forshed induckshun?
  #6
Old 15-06-2008, 05:04 PM
Wavez's Avatar
Trade Rating: (0)
Wavez Executive
ok, yeah when I disconnect it at the battery the battery light comes on and it doesn't charge...
  #7
Old 16-06-2008, 07:32 AM
Ride: VT Berlina & mazda 2 DE
Trade Rating: (0)
bradcad Executive
I have an issue with mine, an auto eleccy cut a section out of the wire and replaced it. Helped, but still had an issue. He suggested I get some fairly thick wire and run direct from the battery + to the alternator +
  #8
Old 16-06-2008, 10:29 AM
Trade Rating: (0)
Quote:
are you refering to the main feed cable? it certainly wouldn't hurt. it'a a pain to do however, getting the old cable out of the loom. would be simple if oyu just cut both ends off and run a new cable outside the original loom
__________________
quote of the week
  #9
Old 16-06-2008, 11:04 AM
Trade Rating: (0)
bradcad Executive
thats what he said- a single heavy wire from the batt + direct to the alternator. In total somewhere around 200mm of cable from memory. I just got a premade battery cable with a lug each end. I am starting to wonder if that is overkil...
  #10
Old 16-06-2008, 11:41 AM
Trade Rating: (0)
considering all the power from the alternator goes through that cable, slightly larger is better then slightly to small. overkill never hurt anybody
__________________
quote of the week
  #11
Old 16-06-2008, 03:30 PM
Wavez's Avatar
Trade Rating: (0)
Wavez Executive
So the small little white wire running from the reg plug I shouldn't worry about upgrading to something bigger yeah?
  #12
Old 16-06-2008, 03:58 PM
Trade Rating: (0)
nah, the little wireshould be fine, just make sure it has a good connection at the battery
__________________
quote of the week
  #13
Old 16-06-2008, 07:34 PM
Wavez's Avatar
Trade Rating: (0)
Wavez Executive
cheers mate.
