aldl cable, help!
Hi,
I have just received 2 max232 ic's and I've got 14 to 21 days to wait for my 16 pin aldl plug.
My problem is I would like a setup that doesn't require any external power sources (ie. Ciggy lighter etc)
Is this possible using EFILive and a serial connection?
I have googled to try and find a solution but have had no luck.
Any help would be appreciated.
Maybe if I send the parts, someone could make one for me?
Cheers, dave
__________________
My Ride:
'94 VR V6 BT1. 15" roh with 225's, stocky with bellmouth removed, OTRCAI, homemade airfilter, B&M Stage1 shiftkit, .490 boost valve. Corvette servo.
Lappy runnin EFILive in a semi stock interior.
WANTED: VN/VP/VR/VS Standard
Memcals.
WANTED: Standard front bar from VR/VS. Prefer alaskan white but will take anything.
Newcastle/Maitland/Central Coast.
Email me
hyp3r4l3rt@hiptop.com.au
