Register - Members List - Calendar - Mark Forums Read -
Go Back   Just Commodores > Holden Commodore Related > Electrical Wiring / Questions
Electrical Wiring / Questions Ask or discuss anything relating to Electrical wiring for your car in here.
Reply
LinkBack Thread Tools Display Modes
  #1
Old 23-06-2008, 07:12 PM
nick88's Avatar
Ride: '95 VS Calais SI
Trade Rating: (0)
nick88 Executive
Default Swapping the internals of an alternator
Hey guys, just wondering if its possible to swap the internals of an alternator over to another case, i scored a 140amp alternator today at work for free, but its off a Gen III V8, and ive got a V6 ecotec, the acutal alternator cases are different but is it possible to put the inside of the gen3 140amp into the case of the vs ecotec one?
and if any one has done it, was it hard??
Nick
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Google Bookmark this Post!Yahoo Bookmark this Post!Bookmark to AskJeeves!Bookmark to Slashdot!Live Bookmark this Post!Spurl this Post!Reddit! Wong this Post!
Sponsored Links
  #2
Old 23-06-2008, 07:21 PM
Peanuts Inc.'s Avatar
Ride: 355 VG :)
Trade Rating: (0)
Peanuts Inc. Caprice
isnt the physical size of the unit bigger tho??
140 amps is a lot of current to run to the battery too, so other things you will need to look at is upgrading your charging wires and the body earths
also those alternators put alot of extra load on your drivebelt which can cause belt squeel and generate alot of extra heat when they are working hard
  #3
Old 23-06-2008, 07:41 PM
nick88's Avatar
Trade Rating: (0)
nick88 Executive
the physical size looks the same,
i already have 4ga charge cable and 4ga ground cables in
ive never heard any gen 3 have belt squeel from the alt, are you sure its the alt that causes it?
  #4
Old 23-06-2008, 08:01 PM
Ride: 355 VG :)
Trade Rating: (0)
thats cause the gen3 is designed to run with it, has a stronger tensioner and the belt contacts more of the pulley which helps the belt not slip.
why do you need a bigger alternator for? running a few big amps?
cos an 85 amp alternator should run 2x1000w monoblocks at full capacity with the headlights on no worries
  #5
Old 23-06-2008, 10:28 PM
VrWagz1's Avatar
This Is Just A TesT!
Ride: Vr S2 exec 5.0 man Wagon
VrWagz1 Berlina
I dont know if they would swap over, but doing the stator windings would be a pain and probably have different mounts, plus you gotta fit the regulator, bearings probably different. My point, more trouble than its worth, unless your completely broke and doing this will help you drive to a pot of gold, i would say dont bother. Go and buy yourself a new one.
__________________
RUST - A good sign its well aged
***Now rollin with roof racks***
  #6
Old 24-06-2008, 05:00 PM
nick88's Avatar
Trade Rating: (0)
nick88 Executive
oohk, sounds like it is a bit more trouble than its worth, main reason i wanted to do it was cause i have upgraded my stock 90a alt to a 100a one off a VT and still have voltage issues, eg, lights dimming etc with bass from subs, n i have all 4ga wiring throughout and the system its self isnt that big..
Nick
  #7
Old 25-06-2008, 12:41 AM
VrWagz1's Avatar
VrWagz1 Berlina
If the lights only dim slightly on bass notes, then its very normal for that to happen as it will drop the battery voltage on those notes ever so slightly and give that dimming effect. If you earthed the amp to the chasis, did you do it properly to a shiny clean bolt, with a properly crimped lug, or did ou just put a tek screw through the floor onto the the paint. Did you upgrade the earth wire going from the battery - terminal to the chasis. Those few things can help a bit, but will not stop it compltely. If your battery happens to die at some stage, then getting a bigger Amp Hour battery may help with it too, but i wouldnt go out and spend a fortune on a new battery just for that.
__________________
  #8
Old 28-06-2008, 05:00 PM
Loud, proud Kiwi
Ride: VP 3.8 Berlina wagon
Trade Rating: (0)
KiwiHoldenDriver Executive
I'd also look at fitting a centre zero ammeter gauge. As long as the ammeter doesn't stay in the discharge side then you will be fine. Minor intrusions into the discharge zone is fine.
  #9
Old 13-07-2008, 06:10 PM
kinga's Avatar
Ride: vs
Trade Rating: (0)
kinga Executive
Have you thought about a farad capacitor instead? May help even out the heavy draw from the bass notes.
Why Use a Farad Capacitor in Your Car Audio System? - WallCannRewards Forum
THis seems to list a farad capacitor as the solution to the dimming lights problem you are having, particularly if you have already upgraded your alternator
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Thread Thread Starter Forum Replies Last Post
engine internals Fast_VR_Boy VR - VS Holden Commodore (1993 - 1997) 1 30-10-2007 11:18 PM
forged internals, how much $$$? PaRaDoX V6 Development And Modification 28 02-05-2007 09:17 PM
253 internals white vn ss VB - VK Holden Commodore (1978 - 1985) 19 06-11-2006 02:06 PM
Upgrading internals on vn v6 ? sobvngrpa VN - VP Holden Commodore (1988 - 1993) 4 21-10-2005 06:36 PM
V6 ecotec (vt) internals SPARK V6 Development And Modification 4 01-06-2005 08:54 PM
Mbna | Remortgages | Credit Cards | Credit Counseling | Fast Loans | Car Reviews
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
