Register - Members List - Calendar - Mark Forums Read -
Go Back   Just Commodores > Holden Commodore Related > Electrical Wiring / Questions
Electrical Wiring / Questions Ask or discuss anything relating to Electrical wiring for your car in here.
Reply
LinkBack Thread Tools Display Modes
  #1
Old 30-06-2008, 11:02 PM
VRV6BT1's Avatar
Ride: S1 VR V6 BT1
Trade Rating: (0)
VRV6BT1 Executive
Exclamation aldl cable!
G'day,
I need a list of parts that I need to finish my aldl cable.
So far I have the 16 pin plug, the max232 chip, a socket for the chip, a suitable circuit board, the d-sub plug and shielded cable.
The only problem is when reading the howto I have a brain fart and have probs figuring out what else I need,
I know I need a transistor to regulate the voltage, a coupla caps(tantalum I think) and some resistors and stuff.
I would really appreciate it if someone could make it simple and give me a list of the parts I need and quantities of the needed items.
Thanks heaps.
__________________
My Ride:
'94 VR V6 BT1. 15" roh with 225's, stocky with bellmouth removed, OTRCAI, homemade airfilter, B&M Stage1 shiftkit, .490 boost valve. Corvette servo.
Lappy runnin EFILive in a semi stock interior.
WANTED: VN/VP/VR/VS Standard
Memcals.
WANTED: Standard front bar from VR/VS. Prefer alaskan white but will take anything.
Newcastle/Maitland/Central Coast.
Email me
hyp3r4l3rt@hiptop.com.au
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Google Bookmark this Post!Yahoo Bookmark this Post!Bookmark to AskJeeves!Bookmark to Slashdot!Live Bookmark this Post!Spurl this Post!Reddit! Wong this Post!
Sponsored Links
  #2
Old 01-07-2008, 02:08 PM
Ride: VL 5L inj
Jayme Executive
Bah, who needs a max232,
I just made this circuit:
http://www.home.aone.net.au/~techedge/vehicle/2tran.gif
2 transistors, 2 resistors and a diode,
bought a 9 pin serial plug and made the circuit free air and squished it into the serial plug. use sheilded cable between the laptop and car otherwise you will get bad frames and the data link will drop out all the time.
only downside is that you need an older laptop with a serial port.
I have had that circuit working on a VN, VR, VS, and VX in Efi live. Nice simple cheapo way out.
  #3
Old 01-07-2008, 05:30 PM
Ride: VRII Acclaim
Trade Rating: (0)
kopper69 Statesman
Jayme, did that one work on the VR, VS, VX too? I thought it was only for the VN?
  #4
Old 01-07-2008, 05:46 PM
Ride: VL 5L inj
Jayme Executive
There is one floating around with only one transistor, which is why it only works on the vn/vp as it only needs to read the data stream, not write to it.
The circuit I posted also has a 2nd transistor which allows 2 way communication for the laptop to be able to signal the vr/vs/vx ecu to begin aldl.
in short - yes it works fine on the vr/vs/vx
  #5
Old 01-07-2008, 06:19 PM
VRV6BT1's Avatar
Ride: S1 VR V6 BT1
Trade Rating: (0)
VRV6BT1 Executive
Ok, so I think the trannys are npn, its been a while is that correct?
Also what type of diode should I use?
Cheers.
__________________
My Ride:
Memcals.
Email me
  #6
Old 01-07-2008, 07:18 PM
Ride: VL 5L inj
Jayme Executive
its been so long that I dont remember what I bought but I just went and ripped it open to get some part numbers.
my transistors are: 2N 3004 610
I think the diode is: 1N4148 (the writing is sooo small)
and 4 10k resitors (one is for bridging the aldl pins if you want to use it on a VN/VP)
I also hacked up a usb printer cable for my sheilded cable :P
I have attached a piccie of my super neat professional setup for reference
  #7
Old 01-07-2008, 08:53 PM
VRV6BT1's Avatar
Ride: S1 VR V6 BT1
Trade Rating: (0)
VRV6BT1 Executive
Sweet, thanks.
Looks like all that other stuff was a waste of time.
I can't wait to get it working.
Quick Q, will this work with EFILive?
Coz the documentation refers to max232.
__________________
My Ride:
Memcals.
Email me
  #8
Old 01-07-2008, 09:58 PM
Ride: VL 5L inj
Jayme Executive
yep, had it working fine with efilive.
  #9
Old 01-07-2008, 10:15 PM
VRV6BT1's Avatar
Ride: S1 VR V6 BT1
Trade Rating: (0)
VRV6BT1 Executive
I know its a big ask and might be stretchin the friendship, but if I fudge it, what would my chances be of sendin you the bits and gettin you to assemble for me?(serial end, I've got the aldl plug end ready to go)
I will send you the max232 and prototype board and socket as payment as well as self addressed jobby.
__________________
My Ride:
Memcals.
Email me
  #10
Old 02-07-2008, 01:56 AM
Wavez's Avatar
Ride: VR Berlina M5, VL SL
Trade Rating: (0)
Wavez Executive
GM 8192/160 Baud ALDL Interface
There you go...
I'm actually making one atm with a little help of a mate.
  #11
Old 02-07-2008, 08:23 PM
Ride: VL 5L inj
Jayme Executive
Yeah I dont mind, if you have trouble, let me know and ill PM you with my addy.
I dont mind about payment, as long as the postage is covered, im happy to help
only catch is that I dont have any access to a VR or VS anymore so I can only test it on my VN, which will onyl prove the receive side works, not the transmit side, but if I do a good job there is no reason it shouldnt work.
  #12
Old 05-07-2008, 10:54 PM
VRV6BT1's Avatar
Ride: S1 VR V6 BT1
Trade Rating: (0)
VRV6BT1 Executive
G'day again,
Just a quick question.
Its been a while since I played with lectronics like this.
The ground point in the aldl 2 transistor circuit between the diode and emitter of t1, where if anywhere does that get grounded to.
I apologise for my stupidity.
__________________
My Ride:
Memcals.
Email me
  #13
Old 11-07-2008, 10:37 AM
Ride: VL 5L inj
Jayme Executive
just ignore that part, its grounded through the cars aldl connector
  #14
Old 11-07-2008, 05:16 PM
VRV6BT1's Avatar
Ride: S1 VR V6 BT1
Trade Rating: (0)
VRV6BT1 Executive
Ok sweet thanks, my first attempt failed.
But I'll try again.
__________________
My Ride:
Memcals.
Email me
  #15
Old 20-07-2008, 07:19 PM
