Register - Members List - Calendar - Mark Forums Read -
Go Back   Just Commodores > Holden Commodore Related > Electrical Wiring / Questions
Electrical Wiring / Questions Ask or discuss anything relating to Electrical wiring for your car in here.
Reply
LinkBack Thread Tools Display Modes
  #1
Old 03-07-2008, 08:43 PM
PanthaVS's Avatar
Ride: VS S-Pack SII
Trade Rating: (0)
PanthaVS Executive
Default VS Drivers Electric Window Saga...
Just replaced a broken window regulator...
Yes, i drilled out the rivets, replaced them with small bolts...
i've installed it as per the gregories manual, and made sure it was sitting correctly in the guides at the front and rear of the door...
my problem...
the window doesnt go up properly... it kind of "walks" up... bout half way up, the window comes laterally out of the rear guide... and when it comes back in... and reaches the top, it does go all the way up at the front of the window (near the side mirror) it leaves about 4-5mm to go...
i can grab the window and pull it backwards and it can be "persuaded" to sit right... but it wont do it on its own accord?
anyone had this happen before?
how can i fix it?
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Google Bookmark this Post!Yahoo Bookmark this Post!Bookmark to AskJeeves!Bookmark to Slashdot!Live Bookmark this Post!Spurl this Post!Reddit! Wong this Post!
Sponsored Links
  #2
Old 05-07-2008, 10:08 PM
big m's Avatar
FIGJAM
Ride: vslll v6 2000 olympic series ute, vp v6 sedan
Trade Rating: (0)
big m Executive
yea jus fixed this in the ute have a look down the runners and make sure the rubber is sitting in the runners right and then make sure the glass is sitting in them, when i had these probs with the ute the window would almost start to corkscrew out of the door lol i hope this helps
__________________
Homer: "for once in my life someone is calling me sir without (your making a scene)"
  #3
Old 06-07-2008, 02:27 PM
PanthaVS's Avatar
Ride: VS S-Pack SII
Trade Rating: (0)
PanthaVS Executive
Quote:
been thru all that... the first time i tried to install it... and yeah, didnt put it in the guides (in the felt guides) properly... but re-installed it after aligning the rubber/felt guides properly...
i think it just needs to be run up and down a few times, maybe some CRC808 silicone spray? hmmmmm.....
  #4
Old 07-07-2008, 05:52 PM
big m's Avatar
FIGJAM
Trade Rating: (0)
big m Executive
well it could be the regulator then it might have a slight bend or kink in the runner or something i replaced 1 at work today it had a realy small bend in it and that caused it to run weird
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Thread Thread Starter Forum Replies Last Post
My drivers window came off! roon_VR VR - VS Holden Commodore (1993 - 1997) 3 15-03-2008 07:00 AM
problem with vx drivers electric seat. help tufvxss VT - VX Holden Commodore (1997 - 2002) 1 16-04-2007 06:43 PM
Drivers window SV6 *lebowski* VZ Holden Commodore (2004 - 2006) 3 11-04-2007 04:26 PM
Electric Window drivers side prob VNSSMAN VN - VP Holden Commodore (1988 - 1993) 10 04-05-2006 09:54 PM
Drivers window Dayvo VT - VX Holden Commodore (1997 - 2002) 4 18-01-2006 06:47 PM
Mortgages | Car Accident Lawyer Los Angeles | Mortgages | Image Hosting | Secured Loans | Car Reviews
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
