Wanted: Wiring schematic for INSIDE the BCM.
anyone have the internal wiring digram of the VS commodore BCM's?
if so, would really appreciate LOW, MID & HIGH diagrams...
reason i ask:
I fixed a central locking issue (Drivers door lock when physically pushed up and down would actuate other lockings, but motor woudnt work by itself)
and i followed all the suggestions made on here... including:
1. check/replace actuator
2. check actuator plug
3. check wiring at door hinge
but it still didnt work... so i tested with a multimeter between the BCM plug and the actuator... and it had continuity... so it HAD TO BE the bcm...
being the tight ass i like to be with car parts... i wasnt going to fork out the dosh and buy a new BCM... so i pulled it open... and found a VERY SIMPLE fault inside (Pics and solutions coming in a seperate post soon) and it cost me a wopping 32 cents to fix!
so yeah... since the circuitry wasnt too complex... i was wondering, if anyone has the internal wiring diagrams for the different levels i might be able to work some "upgrade" mods out...?
cheers...
