whats involved with installing power mirrors into a car without.
i have both mirirs and will be getting a switch soon. what sort ow wiring do i need and does it come with the switch or do i need to get a whole loom.
Check out My SV8 One Tonner
You can get a lot farther with a kind word and a gun than a kind word alone
The loom comes in three parts. Centre part plugs into the fuse box for power. Right side connects at the right kickpanel. It goes into the right door and has the mirror switch connector. Left side connects at the left kickpanel and goes into the left door to the left mirror. Pretty simple to install. All you need is a diagram which shows you how the loom is routed through the doors.
is it possable that the loom is already there ready to be hooked up or will i need to get one from the wreckers
