Quote:
Originally Posted by Wavez
How does the max232 chip get power? do I also have to connect pin 16 (12v) aswell as pin 5 and pin 9?
Power comes from the regulator. Power to the regulator is available to the ODB connector. There should be some instructions on making this that provides info on the mode select. Its been a while since I made this one up and cant remember off the top of my head sorry. Make sure you use the right capacitors for your chip too. If you purchase a max232 you will probably need to use different valued capacitors to the ones on the diagram - the instructions that came with the 232 should tell you.
