VN CALAIS has factory central locking, and anti theft module, ive got everything hooked up but dont no where to patch into the central locking, i have both diagrams of the alarm setup and factory central locking, if someone can help me out please! i was trying to hook into the key switch but it didnt work.. need to no if i should stick with the negative trigger setup
Don't blame me, It's that damn percadan..
If you ask me, that stuff rots your brain...
And now a word from our new sponsor.. Percadan? oh crap!
couldnt upload the pics
Hi there Keesh, I would stick with the negative trigger setup for the alarm as your central locking is tripped with a negative pulse.....
The wires you are looking for are: brown/orange stripe and brown/red stripe. Cant remember which one is lock and unlock but just test them and you will see. The wires are located in a few locations. The location i use to use when doing alarm installs is on the right hand side of the steering column. The loom runs parallel with the instrument cluster. It is normally wrapped up in black tape. so just remove the tape and you will see them. there is more than one you just need to test to find which one it is.......You can test the wires with a test light........good luck if you need to know more just ask.......
cheers
Lets work as a TEAM and do it MY WAY!!
