I bought a fog lamp switch from holden yesterday for my vs calais and have installed it via the instructions in this thread:
http://forums.justcommodores.com.au/...g-diagram.html
Now everything is working great but the switch is not lighting up properly
e.g when i turn parkers on the little red dot on the switch lights up(the one that tells you your driving lamps/foggies are on) and when i push the switch to the ON position the green lamp comes on, now looking at my rear demister switch says its supposed to be the other way around! (E.g green lamp comes on with parkers and red dot comes on when switch is activated) i have checked all wireing and everything is correct, but i think the switch i got from holden is back to front if this makes sense!! So what i need is a pic of this switch so i can check mine against it, cheers for any help!!
