Register - Members List - Calendar - Mark Forums Read -
Go Back   Just Commodores > Holden Commodore Related > Electrical Wiring / Questions
Electrical Wiring / Questions Ask or discuss anything relating to Electrical wiring for your car in here.
Reply
LinkBack Thread Tools Display Modes
  #1
Old 03-08-2008, 09:39 AM
Ride: N/A
crwlx4 Executive
Default Probs with VN alt in a Hilux,Flat battery
Just hooked up vn 85 Bosch alternaters to some Hilux`s,The lux`s have external regultors I replaced that with a relay and Ran the charge wire straight to the battery,The prob is that the battery`s keep going flat when sitting for a while ,Is running the charge wire straight to the battery the prob?
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Google Bookmark this Post!Yahoo Bookmark this Post!Bookmark to AskJeeves!Bookmark to Slashdot!Live Bookmark this Post!Spurl this Post!Reddit! Wong this Post!
Sponsored Links
  #2
Old 03-08-2008, 10:18 AM
PanthaVS's Avatar
Ride: VS S-Pack SII
Trade Rating: (0)
PanthaVS Executive
you got a multimeter?
generators/alternators run what is called a "constant voltage" charging system.
Whilst the engine is running test the output voltage of the alternator across the battery terminals (as if checking the battery voltage).
You should see approx 14volts.
Higher than 14 = Regulator isnt working.
Lower than 12 = no charge coming from the alternator.
  #3
Old 03-08-2008, 11:39 AM
Ride: N/A
crwlx4 Executive
The alternaters are fine,Its when the vehicles sit for a few days with out starting,Then battery will drain flat.I`m not much of a alternater person but with the charge wire going straight to the battery Was thinking that maybe the alternater will suck a little power while sitting and I was missing a relay or something to go in between.
  #4
Old 03-08-2008, 12:23 PM
PanthaVS's Avatar
Ride: VS S-Pack SII
Trade Rating: (0)
PanthaVS Executive
there's no relay in between, the alternator is direct connection (Via a fusable link)
Disconnect the negative battery terminal and test the "current draw" when the car is sitting there (Not running)
If you dont have any alarms or exotic equipment, then the draw should be minimal... something like 20mA (confirmation required???) as this will be the stereo memory backup.
if you have a large current draw, then disconnect the alternator, from the battery and test again. this will tell you if its the alternator thats the culprit, or something else.
If you have the same (small) current draw, then i would assume the alternator is fine and your battery is fluffed... (Lead acid batteries can only sustain 2-3 dead flattenings, then they won't hold charge)
  #5
Old 03-08-2008, 01:20 PM
Ride: N/A
crwlx4 Executive
I`ll give that ago,I`ve actually disconnected the charge wire before and the battery didn`t go flat probably just luck,maybe i should check that no power is running through the whole car loos wire touching or something
  #6
Old 03-08-2008, 08:26 PM
Ride: VRII Acclaim
Trade Rating: (0)
kopper69 Statesman
Im fairly sure that if the regulator goes in the alternator you will constantly be drawing power from the battery and will run the battery flat when the car is off.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Totally Flat Battery, Cant get into car Everton VY Holden Commodore (2002 - 2004) 4 08-05-2007 07:20 PM
VN battery going flat whats going on? Gazza2005au VN - VP Holden Commodore (1988 - 1993) 9 09-06-2006 09:59 PM
VS-Battery keeps going flat evanthe mac Electrical Wiring / Questions 4 29-09-2005 08:14 PM
VQ Battery Going Flat VQ Stato Electrical Wiring / Questions 11 11-07-2005 03:29 PM
Flat Battery Randy18 VN - VP Holden Commodore (1988 - 1993) 11 29-03-2005 11:38 AM
Change remore port | Car Loan | Mobile Phones | Internet Advertising | Electricity Suppliers | Car Reviews
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
