+ Reply to Thread
Results 1 to 17 of 17
Thread: USE a FUSE
    VZ SS LS1
    May 2008
    North Brisbane
    Default USE a FUSE
    The other night me and a couple of mates thought it would be a good opportunity to do some random work on our commodores.......
    Long story short, I was hooking up one 30cm Cathode directly to my battery. However after wiring it up, it blew a fuse straight away, WTF.
    Happened again with another higher voltage one! So being new to the whole auto sparky scene we tried it without a fuse. BIG MISTAKE!
    Hooked it up, then the wires started melting ??????? FAAAARK FIRE. Wires lit up in seconds. I watched the flames follow the wire through a hole in the firewall into the cabin!
    Luckily we put it out. But all I could see in my mind was my VT going up in flames ahah. It just burnt a bit of carpet and put sticky wire crap in the engine bay.
    It was wired up to a lighted switch which i think was the problem, the terminals i used might have been touching.. and yes it was all earthed.
    So yeah kids use a fuse ahahaha.
    Any one else had an experience such as this??
    COOEY
    VS S-Pack SII
    May 2008
    correct me if im wrong... but arent Lead acid batteries capable of instantaneous 400Amps if shorted?
    VZ SS LS1
    May 2008
    North Brisbane
    CANYONERO's Avatar
    CANYONERO is offline Likes Cheese... CANYONERO Calais
    V8 6spd wif MOMO leavaa.
    Mar 2006
    Country SA
    i managed to weld a screwdriver to my amp years ago lol. i was tightening the positive cable and i accidently touched the body of the amp. zap. the fuse worked but took a couple of seconds. amp stopped working too. replaced the fuse and took the amp apart and resoldered the fried power wire and away it goes. i still use the same amp 5 years later on my VY!
    daron's Avatar
    daron is offline wizfiz daron Berlina
    VE SSV
    Mar 2006
    adelaide
    at work i see heaps ppl put their amp fuses in the boot nut under the bonnet and i tell them its not a good idea they shrug their shoulders
    and for the record it takes 5 secs to melt wires from battery to boot and make carpet catch fire
    so if your doing 100 on freeway youll be on fire b4 you get a chance to pull over and go wtf is this
    VZ SS LS1
    May 2008
    North Brisbane
    ahah yeah man, it took like 2 secs to get from the battery to the footwell in mine.
    daron's Avatar
    VE SSV
    Mar 2006
    adelaide
    VrWagz1's Avatar
    VrWagz1 is offline The Wagon on Wheels.. VrWagz1 Monaro VrWagz1 Monaro
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Quote Originally Posted by PanthaVS View Post
    Dont fully quote me but i think it is in the thousands on the instantanious front.
    Reaper
    Phreddy's Avatar
    Phreddy is offline Bye SV6 - still love you Phreddy ClubSport Phreddy ClubSport
    VS-II Statey-8
    Apr 2005
    W-Sydney NSW
    You're right VrWagz - THOUSANDS of amps for an instant, if the short is low enough resistance - before the out-gassing builds up too much hydrogen pressure in the battery and it explodes! (I haven'te ever seen this happen, but a mechanic mate of mine told me about it happening when a bloke dropped a spanner across a pair of terminals - it welded itself to the battery terminals, a few second later the battery showered acid all over the workshop...)
    Always - no, ALWAYS - use a fuse, and as close to the battery as possible. Don't doubt for a second that there's enough energy stored in your battery to set fire to your ride literally within seconds - as Daron suggested if you're mobile at the time, it's already well on fire by the time you pull up. All you have time to do is bail out and RUN!
    New look ASR Website online now!!
    www.asr-audio.com.au
    Interior lighting and audio specialties
    for VT/VX & VY/VZ Commodore / Monaro
    NOW VE DASH LIGHTING CONVERSIONS!!
    PLUS TECH2 DIAGNOSTIC SERVICES
    JBL Car Audio dealer
    immortality's Avatar
    immortality is offline crappy ol' VN driver immortality W427 immortality W427 immortality W427
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    Quote Originally Posted by Phreddy View Post
    this is the exact reason i keep a fire exstinguisher in the front passanger foot well and not in the boot
    Body by Holden, Soul by Brock
    the Legend will live forever
    CANYONERO's Avatar
    Mar 2006
    Country SA
    Quote Originally Posted by immortality View Post
    its a good idea but i find fire extinguishers butt ugly. so i keep mine in the boot. the way i figure, better to have one in the boot than none at all
    VS S-Pack SII
    May 2008
    ahhh... gotta love Lead-Acid batteries! :P
    the fuse should always be pretty much ON the battery! :P (really i mean within a foot of cable, but i like to exaggerate to get a point across)
    fire extingiushers are a good idea for people running amps... but consider your boot is on fire... and thats where a (pressurised) fire extinguisher is.... 1. can you get to it past the flames.... 2. will it explode if you cant?!
    the fire extinguisher should be a PRACTICAL addition to your motor vehicle... NOT a "look good" addition... hence... it will never look good in the cabin... but it will be practical!
    DannyboyDS is offline Just hand me the pliers. DannyboyDS Monaro DannyboyDS Monaro
    VS Berlina
    Feb 2007
    CANYONERO's Avatar
    Mar 2006
    Country SA
    Just what i want, HOLY crap my car is on fire. now where did i hide my fire extinguisher and what did i disguise it as? lol.
  15. #15
    daron's Avatar
    VE SSV
    Mar 2006
    adelaide
  16. #16
    CANYONERO's Avatar
    Mar 2006
    Country SA
    yes.............. i knew what you were going to say before you said it lol.
    if its good enough for HSV to put on it in the boot, its good enough for me......
  17. #17
    Aug 2004
    400amps but its only 12 volts
+ Reply to Thread
  1. Fuse 10, VS
    By mildewmatt in forum Electrical Wiring / Questions
    Last Post: 02-06-2008, 06:17 PM
  2. Fuse 17 on a vt
    By shadow12 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-05-2008, 12:56 PM
  3. VR Fuse Map
    By Bryzee in forum Electrical Wiring / Questions
    Last Post: 22-10-2007, 05:11 PM
  4. Where is the fuse bos?
    By Shifty1 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 25-07-2005, 09:09 PM
  5. Fuse Box
    By Hgprem01 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-07-2005, 08:35 AM
