| Electrical Wiring / Questions Ask or discuss anything relating to Electrical wiring for your car in here. |
21-08-2008, 03:08 AM
Ride: 99 ute s
air horns
21-08-2008, 06:48 AM
Donating Member
Ride: vy series2 ss crewman
its only a basic wireing job. -ve wire to a good earthing point. then the +ve wire goes into a switch(generally a push button) then to a +ve source. i usually use a wire in the fuse box so a fuse is already in the circuit.
__________________
now with a PHREDDY Blue dash
21-08-2008, 07:56 AM
Donating Member
Ride: WH II Caprice, 5.7
Quote:
Originally Posted by ianf
Since you have replaced the horn and it still doesn't work sometimes I would suggest the problem is at the hornpad or clockspring.
21-08-2008, 10:31 AM
1st VZ with a blue dash!
Ride: '05 SV6 M6
.... or maybe the relay - weak coil or burnt contacts ....
__________________
New look ASR Website online now!!
www.asr-audio.com.au
Interior lighting and audio specialties
for VT/VX & VY/VZ Commodore / Monaro Click the scales if you like - or not - what I have to say...
21-08-2008, 05:21 PM
Ride: 2007 SVZ Wagon
Be careful with the wiring as I think (THINK) that the VE like VZ is Negative Earth. You will have to re-think the wiring to and from the relay.
21-08-2008, 11:42 PM
Ride: 99 ute s
Tell me more about the coil & contacts?, I had a bloke at Utratune tell me my coil was not well?, not that him saying this means anything but now that you've also thrown it into the mix I'm starting to wonder???
22-08-2008, 12:08 AM
This Is Just A TesT!
Ride: Vr S2 exec 5.0 man Wagon
There worth bugger all, just by a new one and replace it, you cant repair them. Or swap it with another one to see if your horn works with another relay.
__________________
RUST  - A good sign its well aged
***Now rollin with roof racks***
22-08-2008, 08:45 AM
Ride: '05 SV6 M6
Sorry Mate, I'm talking about the "coil" inside the relay. I'm pretty sure any Ultra Tune bloke would have been taking about your ignition coil.
See, a relay has a coil in it - that's how it works. A relatively small amount of current flows through the coil in the relay, and the electromagnetic effect pulls on an armature - attached to the armature are contacts which can handle MUCH more current. That way you can use a switch that has a low current rating to control a load with a very high one.
I'm pretty sure you'll find your horn relay under a cover on the drivers side under-bonnet, forward of the wheel arch. It just unplugs, and a replacement isn't expensive even if it doesn't help. Or if one of your mates has a similar car, try his relay - if that works, then you know!
__________________
13-09-2008, 10:22 PM
Ride: VZ SV6
piece of cake!!!!
fitted airhorns under the hood with an relay (fused from the battery to the 30 pin) but instead of earthing the relay (pin 86 or 87 me tinks see diagram on relay) i hooked it up to the wire (from the factory horn)that is the earth wire through the horn button on the steeringwheel.
14-09-2008, 05:48 AM
Ride: vx
its only a matter of language, but to speak in terms that wont confuse anyone, refer to the coil in the relay as a solenoid.
In combination with the iron core that goes through the centre of the solenoid, this then is known as an electromagnet.
Older oil filled ignition "coils" with their primary and secondary coils wound in solenoid fashion could also be obviously referred to as solenoids, but no one in the motor trade does.
14-09-2008, 05:50 AM
Ride: vx
Quote:
Not sure what you mean here, negative earth is what all our cars have, except for some older british cars etc?
The contact in the steering wheel just makes a connection to the chassis so current can flow through the solenoid in the relay?
15-09-2008, 03:10 PM
Forgotten...but not gone!
Ride: 01 Taurus!
the only thing I can think of is that BenBoy was refering to the switching of the horn. The wire from the horn to it's relay is negatively switched...Perhaps thats what he was talking about?
__________________
15-09-2008, 03:21 PM
Ride: 01 Taurus!
oops, essentially what you just said. lol
__________________
15-09-2008, 04:30 PM
black is back.
Ride: VU Ute 3.8 S V6
i pulled my air horn kit out of the box....
then booked in with my auto sparky haha.
__________________
KP's S Pack V6 VU
MODS:
- 20" Jet League F-22's all round
- Lovells springs in rear, Kings in front
- Advance extractors
- Custom full mandrel bent 2.5" exhaust from cat
- Altezza head and tail lights
- BILLET Products short shifter
- Mirror tint
- NGK Iridium plugs
- K&N pod
- HSV front bar
