Register - Members List - Calendar - Mark Forums Read -
Go Back   Just Commodores > Holden Commodore Related > Electrical Wiring / Questions
Electrical Wiring / Questions Ask or discuss anything relating to Electrical wiring for your car in here.
Reply
LinkBack Thread Tools Display Modes
  #1
Old 31-08-2008, 05:36 PM
308commodore's Avatar
308 commodore
Ride: 308 VK CALAIS
Trade Rating: (0)
308commodore Executive
Talking Help - VS headlights - one bright one dull
hey guys, as the title says my missus car has something going on with it. a little while back lights were fine then one day i hafd the lights on low beam and the drivers side is only on parkers while passengers is working properly. same with the high beam. it seemed to sort it self out. but today i had the missus car apart ( headlights and taillights ) out while i undercoated the car. put everything back on the and pluged it all in and it's playing up again. drivers side is only on parkers??? also took it for a drive tonight and all the lights including the dash lights and instrument lights were flickering everytime i hit the littlest bump. got it home let it idle and the lights didn't flicker once. it's starting to drive me nuts. i really appreciate anyones help.
cheers ray...
__________________
Go the allmighty 308 if the bloody thing will run!!!
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Google Bookmark this Post!Yahoo Bookmark this Post!Bookmark to AskJeeves!Bookmark to Slashdot!Live Bookmark this Post!Spurl this Post!Reddit! Wong this Post!
Sponsored Links
  #2
Old 31-08-2008, 09:23 PM
r_i_d_a_h's Avatar
Ride: 97 VS Commodore
Trade Rating: (0)
r_i_d_a_h Executive
hrmm just a thought, have you checked the contacts in the plug?? maybe give it a bit of clean
  #3
Old 31-08-2008, 09:33 PM
VrWagz1's Avatar
This Is Just A TesT!
Ride: Vr S2 exec 5.0 man Wagon
VrWagz1 Berlina
Tried swapping the bulbs, bulb may be stuffed. other than that follow the wiring to each point and make sure its all nice, clean and tight.
__________________
RUST - A good sign its well aged
***Now rollin with roof racks***
  #4
Old 01-09-2008, 05:18 PM
Ride: VRII Acclaim
Trade Rating: (0)
kopper69 Statesman
Not much we can help you with Im affraid. Going to be a loose connection somewhere as you have found out, just a matter of going over everything that you can, giving it a good wiggle and finding it from there. Wiring diagram would be helpful, gregorys manual has one, otherwise might be one for an auto electrician.
  #5
Old 02-09-2008, 02:06 PM
308 commodore
Ride: 308 VK CALAIS
Trade Rating: (0)
just want to say thanks guy's. problem is now fixed. it was the 2 fuses for the headlights under the bonnet. they weren't blown but not making constent contact. i just bent the 2 tabs on the fuse in the opposite direction just a little bit to force constant connection. so thanks once again.
cheers ray...
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Thread Thread Starter Forum Replies Last Post
WOW bright VK headlights craigvk VB - VK Holden Commodore (1978 - 1985) 18 09-05-2007 09:26 PM
Dull VN VNtoNV VN - VP Holden Commodore (1988 - 1993) 4 09-09-2006 05:57 PM
blinker indicator lights dull harry3 VL Holden Commodore (1986 - 1988) 1 08-10-2005 10:29 AM
dash lights dull OHMYVY VY Holden Commodore (2002 - 2004) 2 07-02-2005 07:44 PM
Dull Thud DJ Majah VR - VS Holden Commodore (1993 - 1997) 6 05-03-2004 10:46 AM
Advertising | Bad Credit Loans | Loans | MPAA | Stag Weekends | Car Reviews
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
