Register - Members List - Calendar - Mark Forums Read -
Go Back   Just Commodores > Holden Commodore Related > Electrical Wiring / Questions
Electrical Wiring / Questions Ask or discuss anything relating to Electrical wiring for your car in here.
Reply
LinkBack Thread Tools Display Modes
  #1
Old 31-08-2008, 05:46 PM
Ride: VL executive
crash3 Executive
Default relays
would faulty relays cause my fuses to melt? i recently had my fusebox replaced in my VL coz the fuses were literally melting onto the fuseblock. i did post a thread that asked about this problem and thanks to all those that helped. but now it is happening again, when i got the car my headlight high-beam fuse was already melted onto the fuse block, but it slowly went downhill from there and several more melted too. now ive had it replaced and it worked fine for a month or so and its starting to melt again. any experience would be much appreciated. thanks guys
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Google Bookmark this Post!Yahoo Bookmark this Post!Bookmark to AskJeeves!Bookmark to Slashdot!Live Bookmark this Post!Spurl this Post!Reddit! Wong this Post!
Sponsored Links
  #2
Old 31-08-2008, 07:20 PM
Ride: vx
Trade Rating: (0)
commsirac Statesman
double post
  #3
Old 31-08-2008, 07:21 PM
Ride: vx
Trade Rating: (0)
commsirac Statesman
I didnt follow what happened last time. What amperage fuses are the ones where the melting is occuring? are they powering headlights of higher than factory stock?
The fuses shouldnt really get hot, though poor/corroded contacts will generate heat.
No, I dont think the relays would have anything to do with it.
  #4
Old 01-09-2008, 04:32 PM
Ride: VL executive
crash3 Executive
thanks mate. the amperage varies from 3 all the way to 25. i still have the headlights that came in the car when i bought it last year, and as stated above the high-beam fuse was already melted. that being said, the headlights suck so im thinkin they will be the factory rating.
  #5
Old 01-09-2008, 04:53 PM
Cane_It's Avatar
Ride: VK Calais 308
Trade Rating: (0)
Cane_It Calais
check the whole headlight loom, circuit for dodgy joins and replace with a single good wire where possible etc, resistance = heat = burning wires and fuseboxes.
check also the headlight switch in the dash for burning around the back where the plug goes on.
there was a thread on here a while back about running the headlights off relays and using the wires from the factory switch to the fusebox to trigger the relays so you get the full 12V to em instead of 10V.
the other option you have which can be used in conjunction with the relays is a circuit breaker in the headlight circuit which can be mounted in the fusebox if you have a spare spot where a relay would normally go.
__________________
football meat pies kangaroos and holden cars
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Air Horn relays???? Semtex General 6 10-09-2007 01:16 PM
vk headlight relays Vk-5ltr Berlina Electrical Wiring / Questions 9 10-09-2006 03:38 PM
Help with relays kopper69 VR - VS Holden Commodore (1993 - 1997) 4 05-03-2006 02:34 PM
relays where and when summernats2010 Electrical Wiring / Questions 3 05-03-2006 12:24 PM
relays drewboy Electrical Wiring / Questions 2 27-02-2006 11:50 AM
Auto Loans | Equity Release | Deals On Products | Spanish Property | Credit Cards | Car Reviews
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
