so basically switch everything on, see how much of a voltage drop there is and then consider doin the upgrade if voltage drop too significant,
currently my added accessories
2x 100 w spotlights, (16.6A)
extra dual cigarette lighter/outlet capped at 15A
uhf cb & maglite charger (10A max)
and in the process of adding 300w 12VDC->240VAC inverter (35A Max)
when i turn the spotlights on i do notice a decent voltage drop at idle but once revs are built up voltage drop is removed,
justy goin to see what happens when i wire up the inverter and draw full load, will be interesting,
