Vt Aclaim Power Window R/H/F
Here we go again..Another power window problem... I fitted power windows to my 1988 VT aclaim. All the wiring is fine. I have fitted the fuses and relays. Now the problem. The drivers window is getting power to go up but not to go down. All the other windows are fine The switch is ok.. Clues anyone? If I had the wrong relay in for the drivers window..Would that cause the problem?
