Results 1 to 9 of 9
Thread: Disabling parkers when normal headlights are on?
    VX Executive S2
    Oct 2008
    Default Disabling parkers when normal headlights are on?
    Hey,
    Im just wondering is it possiable to disable parkers while the normal headlights are on?
    I want to be able to turn parkers on to display a blue LED, and when normal headlights are on the blue parker leds are not on.
    if anyone knows is it illegal to have the parker light disabled but the normal headlights on when driving at night?
    VY SS
    Jun 2006
    Albany
    i got blue parkers aswell and when lowbeams are on you cant even notice the blue led
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    Even if you disable them... Youll be disabling your rear plate and brake parkers aswell
    VRII Acclaim
    Jul 2005
    You can, it would require a relay and cutting/modification of the wiring for the parkers. If you are interested let us know and we can design a circuit for you.
    VS Maloo
    Jan 2006
    Hawkesbury
    you should be able to cut the parkers out but as kopper said youd have to use another relay or you might be able to jump it through the headlight relay and use the NC contact if its free.
    --APOC--
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    Would be illegal to do so as the Parking Lights are designed to remain illuminated in the event of a headlight globe blowing thus affording oncoming traffic some degree of safety as to the dimensions and proportions of said vehicle. Think that you will also find that it will be illegal to have coloured lamps illuminated at the front of the vehicle unless it is an emergency vehicle or commercial vehicle with clearance lights fitted.
    VY SS
    Jun 2006
    Albany
    if ya really want to do it i guess this would work, you would need 2 relays one for each side you could prob use 1 but this is prob easier, just make sure u get a relay with an 87 and 87a.
    VX Executive S2
    Oct 2008
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    How about if you swapped your low beam relay (with only a normally open contact) for a new relay with the additional normally closed contact and from the new 87a contact run a new wire to each parker. On a vr/s it would be a simple swap over...not sure with a vx
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
  1. Car lights will turn on parkers but wont show normal driving lights
    By james_vrII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-02-2010, 07:50 PM
  2. disabling airbags vt
    By vtwgn in forum Electrical Wiring / Questions
    Last Post: 23-05-2008, 06:14 AM
  3. disabling an aftermarket alarm
    By lockmac in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-04-2008, 04:55 PM
  4. disabling EGR give more power?
    By SweetWagon in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-10-2007, 09:39 PM
  5. Disabling torque convertor lockup - possible?
    By Clacker in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-04-2006, 11:55 PM
