How do I reset the airbag light on VT commodore, the cluster has been replaced from the original single window to the three window unit
i think you have to take it to holdens to clear the fault??
this has happened to me as well, ive upgraded to a 3 window cluster and the air bag light comes on all the time... no idea why. if i put the old cluster back in light goes away,,
MY RIDE
You definitely need to get your cars to the Holden dealer and get them to hook up their Tech2 thingo. It will be a mismatch between the SRS configuration of the car the higher level cluster came from will be different. (single loop, two loop, three loop etc...)
I would suggest you get this done as soon as you can, it might be that the SRS system doesn't function correctly if it's in a fault condition. I'd also wonder about the legality of driving a car with a current SRS fault....
There is a techline document available here... http://www.excelerate.com.au/downloa...nt_program.pdf
So if the dealer looks at you with a stupid look on his head when you ask him to do it, flash this under his nose and let him be embarrased about a member of the genereal public knowing more about it than him!
Cheerz!
New look ASR Website online now!!
www.asr-audio.com.au
Interior lighting and audio specialties
for VT/VX & VY/VZ Commodore / Monaro
NOW VE DASH LIGHTING CONVERSIONS!!
PLUS TECH2 DIAGNOSTIC SERVICES
JBL Car Audio dealer
