Results 1 to 2 of 2
Thread: vt single window to 3 window dash conversion
    vt executive s1
    Nov 2008
    Default vt single window to 3 window dash conversion
    does any now what i need to do if any to put a lvl 3 dash int my vt , with a lvl 1 in it thanks guys
    VT Berlina S1
    Sep 2007
    It should be plug and play
    Although if you get the dash from a car with different airbags, different sized engine, auto / manual, traction control, different speedo (250km / 220km), and i think wheel size also
    they are all programmed into the dash itself, not the ECU
    So a trip to someone who has a TECH 2 to alter the program is required
    So if you have a VT exec and you get a Calais dash the airbags will be different.
    If you have a V6 and its from a V8 it will also need a trip in.
    But if you do the conversion at home, it wont stop you from driving it into get it reprogrammed, you just get weird things happening like tacho is out or fault lights.
    does that make sense?
  1. single window to three window cluster
    By SSbeast in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-12-2008, 03:30 PM
  2. Replies: 18
    Last Post: 03-11-2008, 04:12 PM
  3. 1 window dash cluster to a 3 window?
    By Youngblood in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-04-2007, 09:45 AM
  4. VY single window sports dash into Executive
    By Ghostdriver in forum VY Holden Commodore (2002 - 2004)
    Last Post: 30-04-2006, 10:00 PM
  5. single trip window to triple window
    By m_nairn in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-07-2005, 08:10 PM
