here is a list of diff trailer plugs and wiring hope this helps someone out if u need help just ask also hopefully i didnt stuff it up
small 6 pin round plug & socket
1 tail, clearance - brown
2 left hand turn - yellow
3 right hand turn - green
4 stop - red
5 brakes - blue
6 earth - white
6 pin socket
6 pin plug
small 7 pin round plug & socket
1 left hand turn - yellow
2 reverse - black
3 earth - white
4 right hand turn - green
5 brakes - blue
6 stop - red
7 tail, clearance, side markers - brown
7 pin socket
7 pin plug
large 5 pin round plug & socket
3 earth - white
5 right hand turn - green
6 stop - red
5 pin socket
5 pin plug
large 7 pin round plug & socket
2 reverse - black
3 earth - white
5 brakes - blue
6 stop - red
7pin socket
7 pin plug
7 pin round heavy duty plug & socket
1 earth - white
2 reverse - black
3 left hand turn - yellow
4 stop - red
6 tail, clearance, side markers - brown
7 brakes - blue
7 pin socket
7 pin plug
7 pin flat plug & socket
2 reverse - black
3 earth - white
5 brakes - blue
6 stop - red
7 pin socket up to plug on bottom
12 pin flat plug & socket
2 reverse - black
3 earth - white
5 brakes - blue
6 stop - red
8 battery supply - orange
9 auxiliaries - pink
10 earth - white
11 rear fog lamp - grey
12 auxiliaries - violet
12 pin socket on top plug on bottom
That's where your multimeter/test light comes in and/or have a look on the as if you was replacing a globe.. Silver plater anyone. Would've been nice if you said thanks first that's all.
Cheers,
Dave
as Dave has said this is where the Multimeter comes in.
Thanks
Sav
Heres the taillight wiring colours for a VR/VS sedan..
R/H turn signal = Blue wire.
Taillights = Brown wire.
Brake lights = Blue/red wire.
Reverse light = Light Green.
L/H turn signal = Light Blue.
gdat brett, thanks for that info, do you know the earth colour? or i guess it'll just be the left over wire hey![]()
I have a 7 pin flat anyone know much about them
