hey guys im rebuilding a vh sl/e and i really hate the fuses they run so what i want to do is rebuild the fuse box using the spade type fuses....
has this been done like is there a panel out there suitable for this or am igoing to have problems from the get go....
basically all im after is a remake of the standard panel to suit blade fuses or a model car that came with one the same size...
any help would be great in this
Bill
Here you go mate, check these puppies out! I've installed a couple of them and they are brilliant!....
Niche Electronic and Industrial Products
Sorry should've added, these are more designed for VL onwards but with a little bit of thinking they will work just fine for a VH
