ok sorry its taking a while got a multimeter ok oh the battery is only 12 months old (abouts), charged and ready to go, tried what u guys said to do when on it was going between 12-14v i assume volts and i had the little dial at the bottom Ohms set to 0-16 v, now this is a prob when the car is off its still putting out the same amount of volts.so the battery drains in a couple of hours, any advise is great thanks. silly me for got to say its a red 202. the indicator stick on collum is a little wobbly would that matter.
If im reading it right, you are saying that the voltage across the battery when the engine is running is no different to what you see when the engine is off?
Engine off, Id expect to see ~12.4-12.7 volts. On ~13.5-14.3(its a vb commodore folks). If no difference or slightly less when the engine is running then this is a definite sign that your alternator isnt doing anything.
If Ive misintepreted, or indeed you have been a bit vague with the measurements then it could still be a current leak.
If its draining that fast it should be fairly straight forward to find the current leak, if there is one.
Have you tried the obvious? ie left the battery disconnected and see what happens? lets assume you have and it remains charged.
Next step would be to measure the voltage of the battery while it is disconnected, put the multimeter on the 0-20V scale so you get a reading to two decimal places. Lets say 12.63V Connect the battery and compare the readings.
Open the door and observe what the reading drops to with the interior light on.
One would expect a tiny difference when the battery is connected, perhaps dropping to 12.62V, due to powering perhaps a clock and the memory of the radio, but otherwise it shouldnt change. If the reading changes by as much as when the interior light goes on, perhaps 12.58V a drop of 0.04V, then there is something using current at too high a rate. The problem now is to find it.
Start by disconnecting wires to the alternator, careful here, they will be live from the battery. Then as suggested look for boot, glove box lights, try disconnecting the radio etc. Also pull the fuses one at a time from the fuse panel.
Hope all this gets you sorted one way or another.
