+ Reply to Thread
Results 1 to 19 of 19
Thread: Headlight commander installation
    SweetWagon's Avatar
    SweetWagon is offline booosted SweetWagon Calais
    VS Berlina Wagon Supercharged
    Jan 2006
    Springwood NSW
    Default Headlight commander installation
    Just wondering if anybody has installed one of these before? Im planning on installing it into my Vn, no more leaving lights on! and automatic headlights
    It basically works like later models with a light sensor on the dash. Before I install it where would be the best place for the sensor?
    I think i have the wiring sorted, the green wire is able to be switched between a +ve feed OR -ve pending what the extra green wire is attached to (see wiring diagram). The headlight switch in the vn simply earths the headlight relay so ill just set the green wire to -ve
    Also the blue wire states to connect directly to the parklight wire, im aware the parklights in the VN run straight through the switch (no relay) but unsure if i should install a relay or run it straight off the blue wire...
    Im also going to install a fuse and switch to the +12v ignition incase i need to override it
    I hope to install this next week so hopefully it will work out, but any advice before i install would be much appreciated.
    Cheers.
    danja's Avatar
    danja is offline Swerves for gay koalas danja W427 danja W427 danja W427
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    I'd suggest the middle of the dash, near the front. I don't know the VN interior that well, but you could probably drill a hole and mount the sensor fairly flush.
    Obviously you just need it somewhere that it will pick up ambient light, but not light from other cars headlights etc.
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    Thanks Danja, had a look there's a spot that looks perfect for it in the center under the windscreen, but it means ill have to loose my dash mat.
    Any ideas about wiring into the parking lights? Just unsure if this module will be able to power the parking lights or should i install a relay?
    Cheers.
    jet-6's Avatar
    jet-6 is offline Yer im that guy! jet-6 Executive
    MY06 VZ SX6 ADVENTRA
    Oct 2008
    East Gippsland, VIC
    Cut cut a small hole in your dash mat
    And the wiring diagram you have showns shows option for parker circuit
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    Quote Originally Posted by jet-6 View Post
    I'm aware of this. What i'm asking is, since the module would be powering the entire parking light circuit, I think it would be best to install a relay, As i don't think this module was designed to run ~10amps.
    Looks like its going to be a mission running the wires from the sensor down behind the dash..
    Hopefully should be a pretty unique mod if all works well. Might do a how-to if anybody interested and i don't see why it couldn't be adapted to any model. only $26 bux from supercheap
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake! DANNY8 Caprice
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    Maybe it has an internal relay for the parkers? When u connect the power up, listen for a click when it sends power out through the wire (determine this by using a test light).
    hakhawk's Avatar
    hakhawk is online now forum adjudicator hakhawk Grange hakhawk Grange hakhawk Grange
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    Quote Originally Posted by vn6pwr View Post
    parkers should draw no more than around 2amps altogether. each parker globe is only 5w.
    edit: cant remember if illumination runs off parker circuit, but even still as DANNY8 said, theres probably a relay inside it that will handle it fine anyway.
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    Quote Originally Posted by DANNY8 View Post
    Quote Originally Posted by hakhawk View Post
    Thanks for the advice, would make wiring it alot easier without the extra relay.
    I opened up the box. it appears to be 2 black boxes that look like relays, anybody confirm?
    And yes Hakhawk instrument illumination runs of the same parker circuit through the switch.
    hakhawk's Avatar
    Jan 2005
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    Awesome just what i wanted to hear! looks like this will be easier than i thought I think the hardest part will be running the wire for the sensor. What do you think will be the easiest route? also to remove the trim that runs along the base of the windscreen, is removal of the speaker covers/end vents needed first?
    hakhawk's Avatar
    Jan 2005
    yep, need to remove speaker grill form memory. which needs the side vents taken off first. once thats off, just run the wire from the center along the channel and down past the speaker down under the dash. should be a walk in the park.
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    Yea should be fairly easy task. Hopefully i can get away with only removing drivers side speaker cover and side vent.. now just gotta find some spare time to install it
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    Finished installing this today works well, very happy with it
    Turned out pretty to be pretty easy. Hardest part would have been installing the sensor on the dash. But as for the wiring, pretty simple:
    Red: Fused +12v Ignition
    Black: Earth
    Blue: Park lights + (Brown - Headlight Switch)
    Green: Headlight Relay (White/Black - Headlight Switch)
    Extra Green: Black
    Ill do a write up if anyone's interested. Costed my $26 at Supercheap.
    TAILS83's Avatar
    TAILS83 is offline alcoholics go to meetings TAILS83 Executive
    VPII Club Sport, Build NO# 339.
    Sep 2003
    Brisbane northside
  15. #15
    VN Series 2, FG R6 Ute
    Aug 2007
    S/E Suburbs
    Sorry to dig up this thread, But I just had a go at installing one of these. Followed your wiring directions, and whenever the module is plugged in, it turns the headlights on. Then they stay on. Red LED lights up and turns the lights on even when the sensor is not plugged in.
    Only difference to your wiring is that I added an extra blue wire to go to my foglamps (when installed) it's currently not connected to anything.
    Any ideas on what might fix it?
  16. #16
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    Quote Originally Posted by stockies View Post
    Have you tried it with the sensor plugged in? When I tested mine the headlights would remain on without the sensor connected.
    Only problems i'v had with mine is the sensitivity is a tad indecisive in dawn/dusk conditions, yet to install a switch to it and adjust sensitivity.
    Also I had problems with a backfeed into the ignition when the parking lights switched on manually, the car would continue to run when the ignition was switched off, I put this down to a design fault in the circuit but I corrected it using a 6amp diode from Jaycar, Part number : P600M
    You have to solder it inline on the blue wire, and it will fix the issue by only allowing the current to flow one way (not back into the ignition). Just make sure you solder the diode in the correct direction.
    Power is measured in DECIBEL
  17. #17
    VL Calais
    Jun 2009
    Black: Earth
    Extra Green: Black
    Hi vn6pwr,
    I am resurrecting this thread, but i have a few questions regarding:
    How did you make these connections? Did you just tap them on? Or did they require cutting and splicing in?
    Also if you leave the vehicle with the lights turned on at the normal control stalk can this unit switch them off? I can't see how it does so according to the wiring diagram.
    Thanks,
    Grogey
  18. #18
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    Quote Originally Posted by Grogey View Post
    Hi vn6pwr,
    Thanks,
    Grogey
    Hi Grogey,
    I made those two connections by splicing and soldering them to the wires behind the headlight switch.
    Once the lights are turned on manually the module has no control over the lights, so it still remains possible to leave your lights on if your have turned them on manually.
    You can however rewire the headlight relay and parking lights to only have power on accessories which would solve this problem, but i found it not needed now as I never turn the lights on using the switch anymore.
    Cheers.
  19. #19
    VL Calais
    Jun 2009
    Hi Grogey,
    Cheers.
    Thanks vn6pwr,
+ Reply to Thread
  1. 6x9 installation
    By kingvt in forum Car Audio
    Last Post: 01-10-2008, 09:59 AM
  2. VS amp installation
    By vsMick in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-10-2006, 01:22 PM
  3. lpg installation
    By stackner in forum General
    Last Post: 05-08-2006, 03:45 PM
  4. need help with crs installation
    By venomous in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-04-2006, 05:54 PM
  5. Sub installation
    By navyboy85 in forum Car Audio
    Last Post: 08-02-2005, 10:35 AM
