Just put a new loom in today for the dash so i can do the L3 cluster upgrade soon. But for the moment, i have no low or high beams on my VR.
I have high beam with the indicator stalk pulled back, and i have parkers and interior lighting.
Being dark now its a bit hard to fault find so ill wait till morning. Any ideas for me so i got a head start in the morning.
I have power at the lights plug in the engine bay, fuses seem fine and i tested both relays and thats as far as i got. Thanks
fuses or relays?
Probably answering my own question, but the power comes through the fuses to the lamps, then through the relays and then the indicator stalk, then the light switch which goes to the bcm and out to earth for the auot off, which is working as it cuts out the parkers when you open the door.
So i have got power all the way to the indicator stalk cause it still flashes the high beams.
So that means it only leaves the wiring from the indicator stalk to the light switch, the light switch and the wiring out of the light switch to the bcm
So if i do some testing in and around there i should see the problem, im thinking switch. Thanks for the help
Edit (next morning): Solved Problem was at the switch. found a pin out Black/white. All good
