Results 1 to 15 of 15
Thread: How to connect neon lights to light switch?
    Jan 2009
    Default How to connect neon lights to light switch?
    Hey guys, was just wondering if anyone knows how to connect Neons to the light switch so ever time at night when you turn the lights on, neons turn on aswell? Cheers
    social's Avatar
    social is offline Commodore Enthusiast
    2006 6.0L VZ Thunder
    Nov 2008
    South Aus
    depending on where you hook it up, eg. the centre roof light has 2 wire running into it, a orange (positive) and a orange with a white stripe thru it (negative), simply splice into those wires and run to ur neons and thats it.
    Jan 2009
    Well im placeing 2 neons at the front - 1 under the passangers side an 1 on the drivers side. So when i turn driver lights on at night the neons come on aswell, not for the centre roof. Iv taken the dashboard off where the light switch is but i dont know which wires to connect the neons too.. Cheers
    SweetWagon's Avatar
    SweetWagon is online now booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    Quote Originally Posted by LukasVSS View Post
    I think you mean the parking lights, Easiest to splice into the wire for the globe on the ciggy lighter.
    -Michael-'s Avatar
    -Michael- is offline Ooh Yeah.
    VT S Pack
    Oct 2008
    I spliced mine into the auto shifter light thing, cause its still there and mines a manual.
    seraphic06's Avatar
    seraphic06 is offline Woodgrain Nut
    VS Esteem SII Wagon
    Sep 2008
    Adelaide, SA
    I connected one to the brown wire coming from the demister swtich. See the following thread:
    Jan 2009
    Yeah i want to put them in both sides at the footwells, but only want them to come on at night when driving, so when i turn my headlights on, the neons come on aswell, simple way of doing that?
    social's Avatar
    Nov 2008
    South Aus
    tbh best bet is to have an alternative switch because if u get pulled over at night, u wnt be able to turn em off without having to turn ur car lights off, get a switch, drill a hole in the flip down plastic piece under the steering wheel and wire it to that
    VLPROJECTING is offline HELP MY VL:)
    vl commodore
    Feb 2009
    sydney
    Jan 2009
    Alright guys here is a photo of the lighter wires theres a brown, black and grey wire but what is what, also iv got a 3 connection switch aswell which the bloke from autobarn suggested, On the switch it says "Power" "Acc" "Ground" But what goes where? Cheers
    HRVATSKI_VOJNIK's Avatar
    HRVATSKI_VOJNIK is offline a.k.a KRIS
    VS Commodore V6
    Aug 2008
    Deer Park, Melbourne
    ok, the gray wire is the light for the cigarette lighter, so when lights are on, it turns on, so i would suggest you "hack it" with another wire that goes to the switch (PWR), then attach the neon to (ACC) just ground the the (Ground) to the black wire(?) might need someone to correct me here. (i only worked on the cigarette lighter once)
    but if you want it to turn on when when the doors are open, then do what Social mentioned, hook it upto the center roof light
    Jan 2009
    Na i just want them to turn on when i turn the switch on just incase of getting pulled over
    VS Commodore V6
    Aug 2008
    just go to Dick Smith or Tandy and buy some 3~5Amp fuses
    then just attach a wire to one end of the fuse, and the other end to the (PWR) on the switch.
    then put the fuse in an empty fuse houseing
    VS Commodore V6
    Aug 2008
  15. #15
    Jan 2009
    Thanks heaps mate much appreciated, thanks all
LinkBacks (?)
  1. 24-11-2009, 06:22 AM
  1. How do I connect rear spoiler brake light in VY II
    By additive in forum VY Holden Commodore (2002 - 2004)
    Last Post: 18-11-2008, 01:29 PM
  2. Wiring fog lights using the fog light switch
    By CacTuar in forum Electrical Wiring / Questions
    Last Post: 09-04-2007, 12:17 PM
  3. neon light?
    By james_and_his_vp in forum Electrical Wiring / Questions
    Last Post: 02-08-2006, 12:00 PM
  4. Neon Switch casing?
    By raZel in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-09-2005, 03:17 PM
  5. Neon light
    By G4orce in forum General
    Last Post: 23-08-2005, 08:39 AM
