Results 1 to 4 of 4
Thread: Rear speaker no work.
    Roh Guest
    Cool Rear speaker no work.
    Hi all,
    I know this is probably a simple question, but my left rear door speaker doesn't work. I think it's probably a wire off at the speaker due to the opening and closing of the door, but has anyone else had this problem? If so, where do you reckon the most likely place is to start looking?
    vlv8vic's Avatar
    vlv8vic is offline <---Brad Quaid = internet stalker
    M5
    Mar 2005
    Australia
    If not directly behind the speaker check in the door jam. Behind the head unit is your next best option it may not have been connected properly and has come loose
    HSV VN Guest
    Hi Roh,
    It all depends on how your rear speaker is hooked up. Assuming it's to the head unit, be sure the connections are ok. Firstly try that channel on a different speaker. If it works, check the connection at the speaker end of the wire at the rear speaker in question. If that still doesn't work, try using a different wire. Also make sure on the headunit you don't have it faded/balanced everywhere except that speaker!
    Now, if it's on the Amp, do a test exactly as above. You may have blown a channel.
    All that failing, try a new speaker, that one may just be shagged. Hope it helps. PM if it's too hard to understand.
    Roh Guest
    Thanks for the help guys. I'll sit down with your advice and go through it.
  1. VT rear speaker grills
    By andrewgrazier in forum Car Audio
    Last Post: 22-02-2011, 12:37 AM
  2. Rear speaker grills
    By t-rev in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-04-2006, 02:26 AM
  3. Rear Speaker Replacement on VX
    By girlracer in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-02-2006, 02:42 PM
  4. Sv6 rear speaker wiring
    By suppy in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 05-09-2005, 10:15 PM
  5. Rear speaker no work
    By Roh in forum Car Audio
    Last Post: 21-05-2005, 02:56 AM
