Results 1 to 3 of 3
Thread: Wiring in "auto lights off" module
    VN Series 2, FG R6 Ute
    Aug 2007
    S/E Suburbs
    Default Wiring in "auto lights off" module
    Hey everyone, I was given one of those auto headlights off modules from supercheap auto for christmas, and I've finally got the time to install it, only i don't know how.
    Has anyone installed one of these before? The instructions are quite vague.
    If someone could check if this is right:
    Red wire: To positive 12v ignition ( This goes to a White/green wire ACC yeah?)
    Black wire: To -ve ground ( This goes to metal)
    Blue wire: 12pos output to parklight wire (This goes to the parklight wire on the headlamp switch yeah?)
    Green wire: To headlight relay circuit ( This goes to the relay under the bonnet yeah - but which pin?)
    Extra green: a:If relay circuit requires pos12v feed, connect this wire to the red one.
    b:If -ve grounding is required, connect to black wire. (It would go to the black wire yeah, cos VN's have a switchable ground?)
    Also I want to connect a set of aftermarket foglights to this, is this possible?
    Sorry for all the vague questions, but i'm not 100% on this.
    Thanks guys.
    seraphic06's Avatar
    seraphic06 is offline Woodgrain Nut
    VS Esteem SII Wagon
    Sep 2008
    Adelaide, SA
    SweetWagon's Avatar
    SweetWagon is online now booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    Quote Originally Posted by stockies View Post
    Thanks guys.
    Your in luck, thats my thread seraphic posted i recently done this mod so any questions just ask.
    Just a few things, I needed to extend the wiring to the sensor (just used some speaker wire). Also, unfortunately it doesn't come with a fuse so you can buy your own or do what i did and spliced into a fused ignition wire under the dash. I think it was fuse #10 or #11 i used..
    Its up to you whether you install a switch or not, incase you want to override the system.
    Red: Fused +12v Ignition
    Black: Earth
    Blue: Park lights + (Brown - Headlight Switch)
    Green: Headlight Relay (White/Black - Headlight Switch)
    Extra Green: connect to Black
    You can use it to control fog lights too, run another wire from the blue to the positive side of the coil on the fog lights relay.
  1. VT calais "auto" headlights not functioning properly
    By muneey in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-10-2008, 04:16 PM
  2. The "gears" and "power" in an auto
    By nath_120 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-07-2006, 08:59 PM
  3. DFI module "cooks" (smokes, and the gel bubbles)
    By Irr in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-06-2006, 07:12 PM
  4. Wiring help for VT "S" driviing lights
    By sweetfa in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-05-2005, 05:11 PM
